Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Wisconsin V4 Stuck valve
jack345
12-25-2012 08:48:49
I just got a Wisconsin V4 not sure what model it is as its hard to find the engine tag , looks like a later model as it has belt driven altenator and alloy heads.It also has a stuck exhaust valve been trying to free it up with chemicals,Kroil, etc. I do know it may be best to pull head and remove valve,clean but concerned about the head bolts breaking.
Is there a tool that reaches in thru plug hole to push down the exhaust valve without removing head? Also is there a location where the engine tag is found? Thanks. Jack
jack345
12-27-2012 08:47:05
 Re: Wisconsin V4 Stuck valve in reply to jack345, 12-25-2012 08:48:49
Thanks, just the info I needed.
Bill(Wis)
12-26-2012 06:07:14
Once you get it freed up, ALWAYS use Valve Ease as a fuel additive. Those Wis V4s are notorious for stuck valves.
JOB
12-25-2012 13:50:27
You most likely have a VH4, could be another. I just freed up a stuck valve, or maybe a sticky valve, in a V4 Wisconsin.
I had the engine off the machine. What I did was tip the engine so what ever you poured in through the spark plug hole would run into the exhaust port. I let it soak for awhile , then cranked the engine over until it had compression. Worst case is remove the intake, exhaust manifold. Then remove the valve cover and see if you can at least move it a little. If you can move it a little filling the port with oil and cranking the engine with all the spark plugs out might do the trick. Good luck
Phil-Mar Farms
12-25-2012 12:33:56
Some times you can reach the valve with the short end of an allen wrench. Before you try the head bolts give each one a solid rap with a stout punch and a good size hammer. Vibration breaks the rust crystals.
wisbaker
12-25-2012 10:31:49
Make sure that when you're letting it soak the crank is positioned so the valve train isn't holding up the valve. Did and old Rambler twice, 1st time I took the head off (Flat head 195 straight 6), second time worked it with WD-40 and various tools through the sparkplug hole. Everyone here has their own secret formula for freeing stuck engines most have ATF in the mixture.
old
12-25-2012 09:04:35
Wick or dump out the Koil and fill with ATF. ATF has been proven to work far better then most any thing else. As I said fill it and if the exhaust goes down cover it so it can not leak out the exhaust pipe and let it sit a few days. Can not say on that engine but many engines I have played with you can take a bent screw driver etc and push the valve down.
