TractorLinks.com
Tool Talk Discussion Forum
Re: Welding Rod--What to use it for??
Stick welding
12-24-2012 11:36:13
7024, commonly referred to as Jet rod. Actually Lincoln calls their 7024 Jet. It's not low hydrogen so doesn't need an oven, only needs to be kept dry. It has a heavy iron powder flux and is a high deposition production rod. Most 7024 applications have been taken over by flux-core. 7024 was used a lot for things like large oilfield tanks, welding checker plate on skids and other high production non critical welds. It is a drag rod but sometimes holding the arc just off the slag works better than dragging. The heavy slag should peel off almost by itself, leaving a very smooth weld. A 1/4" 7024 will burn a 1 1/2 to 2 ft. bead depending on what your welding. Is a good general purpose rod for flat and horizontal welds. Have to be careful with the heat as too many amps will leave blisters in the weld. Usually about the same heat as 7018 depending on what brand.
