Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Using speakers with a device which is recharging
MarkB_MI
12-24-2012 02:45:23
The only issue is whether the power supply for the MP3 player can provide enough juice to power the player, charge the player's battery and have enough left over to provide juice to the USB port. USB 2.0 normally can source up to 100 milliamps, although there is a "battery charging" spec that can source 1.5 amps. My guess is your speakers draw the full 100 milliamps when charging, Take a look at the specs on the charger for the MP3 player: if it's only rated at, say, 120 milliamps, it's probably not going to be able to charge both the speakers and player simultaneously and still be able to operate both devices. It's not going to hurt anything, it will just never finish charging.
Safest thing to do is to bring both devices to a full charge before hooking them up. Then the charger for the MP3 player should have no problem keeping them both charged.
Stan in Oly, WA
12-24-2012 09:22:54
 Re: Using speakers with a device which is recharging in reply to MarkB_MI, 12-24-2012 02:45:23
Thanks, Mark,
Since I know so little about this, I don't know if this matters, but it might. One of the speakers attaches to the MP3 player via a single prong earphone type plug. The speakers attach to each other using a different type of plug. They charge through a USB plug, which is not connected during normal play---although possibly it could be. The speakers work when the MP3 player is not connected to anything else. Previously, using speakers which did not have batteries, my wife would frequently use the speakers while the MP3 was plugged into a 120 volt outlet, as for recharging. In this configuration, the speakers did not drain the MP3 player's battery so quickly---maybe not at all. I hope that's clear. I have a feeling that if I didn't have everything where I could see it, it wouldn't be clear to me.
My wife's concern is that nothing in the literature accompanying the speakers mentions whether it is safe to use the speakers while the MP3 player is plugged in for recharging. We wouldn't expect them to recharge in this case---only to not discharge the MP3 player's battery.
Does any of that change anything?
Thanks,
Stan
