TractorLinks.com
Tool Talk Discussion Forum
Re: sharping hand saws
Stephen Newell
12-21-2012 20:57:18
I have just put the saw in a vice and used a triangular file to sharpen one. You can't do it move than a couple of times because you end up taking the set off the teeth.
Dick2
12-22-2012 02:14:13
 Re: sharping hand saws in reply to Stephen Newell, 12-21-2012 20:57:18
My Dad used to have a tool to put "set" in saw teeth. I think it might still be in the old machine shed at the farm, but I doubt that my younger brother would even know what it is if he found it.
Just use an appropriate file and try to maintain the original angle on each side of the tooth. If the angle is gone from previous sharpening, you need to re-establish a correct angle on alternate teeth.
KEH
12-22-2012 05:13:32
 Re: sharping hand saws in reply to Dick2, 12-22-2012 02:14:13
Clamp in vice. Use triangular file to sharpen. Get a new medium sized file, don't remember the number, file is in barn and I don't want to walk there in cold right now. Take saw to harware store and get one that fits teeth. Keep file level, keep same angle as some sharp teeth on saw. Sharp teeth can be found near the handle. Saw set is hopefully still made by Stanley and you can get a new one, they're not too expensive, or didn't use to be. Or you can use a small punch to carefully bend the teeth over in line with the good teeth. The saw should be jointed, or checked to see if the teeth are in line and that there are no dips in the line of teeth. To joint the saw, take a flat file and lay it flat on top of the teeth. If there is a serious dip, the cure is to file the teeth flat and cut new teeth, resetting them.
Lyle can describe the procedure for sharpening a circular sawmill saw.
KEH
