TractorLinks.com
Tool Talk Discussion Forum
Re: A Few Tips on Warpage...
Puddles
12-20-2012 08:14:48
Stephen it's about weld sequence, back stepping your welds, and moving around a lot. Never start at one end of a project and continually weld to the other. All very helpful tips when fabricating.
scotc
12-25-2012 11:17:53
 Re: A Few Tips on Warpage... in reply to Puddles, 12-20-2012 08:14:48
Like stitch welding sheet metal. Make a series of spot welds every 6 inches or so, work end to end, then go back and do it again.
Stick welding
12-20-2012 19:12:37
If your welding something like a trailer or skid in place, it helps to do the vertical welds first, then top and bottom. Of course jumping around so all the heat isn't in the same place. I built a lot of big skids and they were turned so all the welding was done flat or horizontal. They all warped downward. To straighten them, we flipped them upside down and applied heat to the main beams at the I beam cross members in the middle. They were sitting on short pieces of I beam blocks at the corners, the same as when they were first started. After heating the finished skid, they straightened right out. Some of the skids weighed 10 tons.
