Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Topic: Adjust/square bandsaw blade
[Return to Forum]
1 Dollar
12-19-2012 21:16:24
50.90.29.53
I bought a used Buffalo horizontal band saw, put a new blade on tonight and did just one test cut and it cut less than square. Anything to adjust to correct this? It cut shorter/the blade went towards the clamp.
Thanks
[Reply]   [No Email]
jon f mn
12-20-2012 05:10:38
70.194.71.146
Re: Adjust/square bandsaw blade in reply to 1 Dollar, 12-19-2012 21:16:24
If your saw cut straight before it's probly a bad blade. The quality of the blades can very a lot. If you bought a cheaper blade to save money you may have just learned a lesson I learned a couple of times over. Of course I've gotten a couple of bad blades from quality suppliers too, but they always take them back and replace them.
  [Reply]  [No Email]
jon f mn
12-20-2012 05:09:18
70.194.71.146
  [Reply]  [No Email]
Butch(OH)
12-20-2012 04:29:43
70.62.13.146
Both problems mentioned are correct. Setting the guide rollers can be tedious. You need to lay a square across the bed and up to the blade and a good light behind it so you can view the light between them. Remember the blade has a "set" to the teeth that makes them wider than the back. So with the square up against the teeth you should see light between it and the rest of the blade. You want that gap even. Then install a new QUALITY blade and it will cut square. Then try the old one and it it cuts crooked you know what to do with it. I got caught without a spare for my 7x11 saw a couple times and my experience with pre-packaged blades from the the hardware stores is dismal or worse. Go to one of the on-line tooling stores and have them make you up some bi-metal blades. Lennox, Morse and Starrett are all good brands.
  [Reply]  [No Email]
Stick welding
12-20-2012 22:10:10
96.53.210.246
Re: Adjust/square bandsaw blade in reply to Butch(OH), 12-20-2012 04:29:43
Wikus are very good blades as well. If there's a place around with a blade welder, don't throw out broken blades. They can often be re-welded a couple times until you run out of adjustment. If you have a couple short blades in still decent shape, you can make a long enough blade out of the 2 but with 2 welds. Always break in a new blade for the first few cuts. Run it with about half the normal feed rate.
  [Reply]  [No Email]
Dick L
12-20-2012 06:18:06
184.8.50.65
You can take the set out of one side of a quality bimetal blade if you crowd it. They need a little break in time when first put on as well. Last week I cut some 3 inch pre hard tool steel with an old blade that was off 1/4" top to bottom. I had force cut some steel a while back to hurry up a job.
  [Reply]  [No Email]
Butch(OH)
12-20-2012 06:49:41
70.62.13.146
Re: Adjust/square bandsaw blade in reply to Dick L, 12-20-2012 06:18:06
Thanks Dick I always forget to mention that and it is important. To break in a new blade I use a piece of leadalloy round stock about 3" diameter and shave off a couple 1/4" disks with light pressure and lots of coolant. Forget who told me that, was it you? Anyway it adds measurably to blade life in shops cutting new steel. The best blade life increases in the average farm shop will come from NOT cutting rustly and welded junk in the saw and checking unknown parts with a file or hand saw prior to dropping the band saw on them and hearing SCREEEEEECH!!
Darned amazing what some people put in a powered saw and expect it to cut!!
  [Reply]  [No Email]
Dick L
12-20-2012 12:12:18
184.8.50.65
Re: Adjust/square bandsaw blade in reply to Butch(OH), 12-20-2012 06:49:41
Ya tell me about it. When I had three shifts six days a week here some times a blade changed one day was shot the next. Of course no one had used the saw since the new blade was put on. It just came with no teeth. Mold clamp allen bolts was more than likely the cause. Try the saw before using a cutoff wheel, might be faster.
Gotta be carefull here. DiyDave will pop in and tell me I am off topic again. (:^D
  [Reply]  [No Email]
johnpop1
12-20-2012 03:58:17
108.4.131.245
Old has it right! Keep in mind the quality of the machine is less than stellar.
  [Reply]  [No Email]
Hendrik
12-20-2012 01:40:22
194.53.253.51
If your machine cut nicely square with the old blade band, there may be something wrong with the new blade band. The lateral set of the teeth may not be symmetric. I do not think this can be practically remedied. Throw away and buy a better blade.
HTH, Hendrik
  [Reply]  [No Email]
Jerry/MT
12-19-2012 22:41:52
206.183.116.145
Using a square, check fore perpendicularity in the vertical plane and the horizontal plane.
  [Reply]  [No Email]
old
12-19-2012 21:25:36
209.86.226.11
It should have a set of 2 or 3 guide bearings that can be set so as to make the blade run more true and square. The guides also need to be as close to the metal your cutting as you can have them and yet not cause it not to be able to cut
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
