TractorLinks.com
Tool Talk Discussion Forum
Torque wrench
Slowpoke
12-18-2012 20:54:08
I need to torque a nut to 9-11 ftlbs but can only use a crowfoot on the nut. How do I figure the torque if the center of the nut is 1" from the center of the 3/8 square drive on the wrench? Or is the distance too small for concern?
Thanks
Indiana Ken
12-19-2012 05:51:47
 Re: Torque wrench in reply to Slowpoke, 12-18-2012 20:54:08
The formula is:
Tw = (Ta x L) / (L + E)
Where:
Tw is the torque indicated on the wrench
Ta is the torque applied at the adaptor
L is the lever length of the torque wrench
E is the lever length of the adaptor
Note, all lenghts are center to center.
In your case to apply 10 ft-lbs; (10 x 12) / (12 + 1) = 120 / 13 = 9.23. Therefore setting the wrench to 9.23 ft-lbs would apply 10 ft-lbs at the bolt.
Also, positioning the adaptor at a right angle to the wrench requires no adjustment to the wrench setting as previously posted.
Butch(OH)
12-19-2012 05:20:50
I tend to agree with Pentex. When you think about it 9-11 is close to a 20% spread. Adding an inch to a 12" lever is something less than a 10% change. Stick the crows foot on sticking out and use the top end of the spec, or turned back at you and use the bottom. Turning it to 90 degrees also works but to nit pick that is not exactly the same either (I know really nit picking that point) Bottom lie is torque doesn"t keep the fastener tight, stretch does and many factors affect how much stretch you obtain at "X" torque. This was all beat into my feeble brain on a critical application where we left the torque wrenches in the box and had to obtain a certain stretch as measured with a mircometer. Bolts were Boron and the applied torque was unbelievable for the diameter.
Dusty MI
12-19-2012 04:50:32
I needed to do that once. I turned the crow foot so it was out the side, then the torque is the same, the lenght of the torque wrench is not any longer.
If the crow foot is 1" long, and you put it stright out, and the torque wrench is 12" long then you have increased the torque on the nut 1/12. So if you set the wrench at 100 lb. then it would be 112 lb. of torque that you applied.
Dusty
This post was edited by Dusty MI at 04:51:56 12/19/12.
johnpop1
12-19-2012 04:47:30
Owen has it pretty much right. Torque is measured by force applied and the distance from application (the lever arm or in this case the distance from the center line of the fastener being turned to the device being used, the torque wrench) With a clicker type torque wrench, it really doesn't matter where you grip the wrench. It will matter how much extra distance you are adding with the crowsfoot socket. As mention above, having the socket offset 90 degrees will pretty much negate any error from the socket. Many torque wrenches are not that accurate and I think that if you pick a torque in the middle of the value required, you will be pretty safe.
jason the red
12-19-2012 03:42:51
One inch won"t matter enough to worry about, as others have stated. Owen is on the right path to figuring out the formula though. I have it written down at work, but you could Google it and find out for sure.
JMS/.MN
12-18-2012 22:11:57
You could grip the wrench an inch closer to the pivot, but for that issue, I wouldn't worry about it. I can't think of an instance where we grip right on the end of the wrench anyway.
Slowpoke
12-18-2012 22:41:51
 Re: Torque wrench in reply to JMS/.MN, 12-18-2012 22:11:57
I should have mentioned that it's a click type wrench.
JMS/.MN
12-18-2012 23:57:20
 Re: Torque wrench in reply to Slowpoke, 12-18-2012 22:41:51
OK, I have one of those for the heavy torks, like up to 400 lbs, but I think the principle is the same...we grab and pull with the whole hand, sometimes both, covering several inches of the handle. I think a purist would attach a cable to the handle, 12 inches from the pivot, if measuring foot/lbs, and pull. and die, but being PC, LOL
petetx
12-18-2012 21:57:55
i am a 72 yr. old retired maintence machinst one inch not enough to worry about.
Owen Aaland
12-18-2012 21:07:53
 Re: Torque wrench in reply to Dave Sherburne NY, 12-18-2012 20:54:08
You need to measure the distance from the center of the square drive on the end of the wrench to the center of the handle where you are applying the torque and figure the ratio to the length of the extension. For example if the wrench measures 10 inches the ratio is 1/10. In that case you would reduce the torque measured on the wrench by one tenth.
It is much easier to just attach the crow foot extension at a 90 angle to the wrench and then use the listed torque. With a 1 inch extension at a 90 angle to the wrench the difference in length between the center of the handle and the center of the crow foot compared to the actual effective length of the wrench is very small.
Slowpoke
12-19-2012 13:14:13
 Re: Torque wrench in reply to Owen Aaland, 12-18-2012 21:07:53
Thanks for all the answers. I"ll go with the 90* angle.
