| Author |
[Modern View]
| TOM N MS
12-16-2012 14:42:41
98.95.135.43
rother is working on one--I told him about the "spin the drill backwards trick but that did not make it start genning.. Yrs ago I "bumped" one with a 12 volt battery but don"t remember Zactly how and I know it"s a little risky..Any other thoughts? Suggestions? Thanks |
| oldfarmtractor
12-17-2012 08:18:16
71.155.238.11
Re: Generator not genning in reply to TOM N MS, 12-16-2012 14:42:41
| I would try to make sure it is a single speed drill. |
| Dusty MI
12-17-2012 10:28:29
76.250.62.134
Re: Generator not genning in reply to oldfarmtractor, 12-17-2012 08:18:16
| I don't believe it matters which you spin the drill, it just needs to be a universal one. But I've wondered if a variable speed one would work ? |
| Dusty MI
12-17-2012 10:26:56
76.250.62.134
| Charles (in GA)
12-16-2012 15:45:36
24.181.69.107
| | Cordless drills don't do it!!! ha ha! I know, not funny. You need an old corded type with a brush type motor. Of course there could be other issues. Charles |
| TOM N MS
12-16-2012 15:57:44
98.95.135.43
Re: Generator not genning in reply to Charles (in GA), 12-16-2012 15:45:36
| You gotta be kidding--cordless Is so much handier--I thought long as U point it at it it would do the same thing...... |
| Billy Shafer
12-16-2012 15:39:33
173.184.35.10
| TOM N MS
12-16-2012 15:56:09
98.95.135.43
Re: Generator not genning in reply to Billy Shafer, 12-16-2012 15:39:33
| I don"t know the model--I think he said it is a coleman 10 hp but I DK the Model or any more info. |
| bo1
12-16-2012 15:14:33
67.252.155.249
| fire it up and plug in a drill, pull trigger on drill and spin the chuck backwards. Keep in mind that if it works, drill will start spinning...move your hand away quickly. |
| TOM N MS
12-16-2012 15:21:41
98.95.135.43
Re: Generator not genning in reply to bo1, 12-16-2012 15:14:33
| Tried earlier today and it did not work..was hoping it could be this simple but....not that lucky. |
| gerry Mann
12-17-2012 19:17:54
108.254.160.157
Re: Generator not genning in reply to TOM N MS, 12-16-2012 15:21:41
| check the capacitor. 9 out of 10 times that is the culprit. |
| TOM N MS
12-17-2012 19:40:08
98.95.135.43
Re: Generator not genning in reply to gerry Mann, 12-17-2012 19:17:54
