TractorLinks.com
Tool Talk Discussion Forum
Re: Fire chief wood furnace
Jim in Ma.
12-12-2012 11:33:08
I put an insert (w/ blower built in) in my fireplace this fall. It sure helps to cut back on the firnace use. Too soon to tell how much savings it will bring.
Rob Mo.
12-13-2012 17:04:36
 Re: Fire chief wood furnace in reply to Jim in Ma., 12-12-2012 11:33:08
I like the idea of an insert, but the cost of one of them vs a wood furnace is about the same. To describe my house its a single story w/ a basement 1200square fpot. Plaster walls on the inside & asbestos siding on the outside. New windows in the fall of 11' & a front door for the main living area ( living room, kitchen, 3 bedrooms & 1 bath). There is a breeze way that is separated by a hollow door that leads to the garage. Mind u, the door stays close to the breezeway in the winter months because of the draft, there is no draft this way. I have a fireplace in the north side of the house main floor & a wood chuck brand wood stove with a blower in the basement below the fireplace, there are 2 separate chimneys of course. Mind u, the wood chuck stove has a blower on the bottom of it, that is connected to a thermostat switch. 150degrees blower is on & off @ 130 degrees. Usually get minute to 3 minutes run time, then off till the fire box gets hot again. 6" pipe with a manual damper connects it to a masonary clay tiled chimney. There is another clay tiled chimney in the center of the house. Will take a 6" pipe that once vented an oil furnace. Thinking about switching to that flue since it is center of the house. If I were to buy a wood furnace by Fire Chief, the 700 is more stove than I need, but if I open the breezeway door, I think it will even the temperature. I would rather go a step bigger in stove size. I live on 170 acres with a 100 of it being woods. Plenty of oaks, hickory, walnut, whatever. I am no stranger to a chainsaw or woodsplitter. Thanks for the input thus far has helped me think about this a lot. Keep it coming.
showcrop
12-13-2012 16:09:23
Be sure to get your mirror in there and look up the flue at least once a month.
