Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Topic: '88 Chevy 350 Electrical Short?
[Return to Forum]
Glenn F.
12-11-2012 17:33:42
166.182.3.210
About two months ago I installed a new battery in my pickup, (which I haven't driven since). The other day I got somehing off the seat & noticed a dim dome light. Of course the starter was too. Upon putting the battery charger on it, the indicator needle stayed on "charged". I left the charger on for about 20 minutes & needle didn't move. I disconnected positive terminal, put charger back on and after about 20 seconds the meter dropped down to the charging position, (50 amp boost charger). I then set it at 2 amps & let it charge up slowly. I have not gotten back to it/hooked battety back up.
Is that initial charging situation normal? Also, how long should a battery maintain enough juice to start a seldom driven vehicle?
Thank you,
Glenn F.
[Reply]   [No Email]
ASEguy
12-12-2012 01:33:14
68.186.162.134
 Re: '88 Chevy 350 Electrical Short? in reply to Glenn F., 12-11-2012 17:33:42
Sounds like you might have a drain. Leave the positive cable hooked up and disconnect and isolate the negative cable. Hook a test light between the negative post and the negative terminal of the battery and see if it lights. If it does, and is not really dim you have a drain and need to disconnect fuses to determine the circuit involved. I use small Vice-grips to hold it in place. Hope this helps. Gerard
[Reply]  [No Email]
nys
12-12-2012 02:48:29
98.15.254.212
 Re: '88 Chevy 350 Electrical Short? in reply to ASEguy, 12-12-2012 01:33:14
I have put an ammeter in series of course on the positive and wiggled wires until it jumps to find intermitent shorts once I know which fuse/circuit its on as previous post described. Good luck
[Reply]  [No Email]
ASEguy
12-12-2012 01:36:49
68.186.162.134
Sorry, I didn't answer your other question. Yes the charging rate you describe is normal for a run down battery. Completely charge the battery and disconnect it if you can't find the drain at this time. Remember not to charge a dead battery if it's frozen. Thaw it first or they can explode.
[Reply]  [No Email]
LJD
12-11-2012 18:30:05
75.250.201.152
There are a lot of newer cars and trucks that cannot sit more then 1500 hours before the battery gets too discharged to start (i.e. two months). All it takes is a built-in 50-100 milliamp draw. Seems though that a 1988 would not have that much draw unless you've got an alarm-system on it.
Besides a small constant draw - any lead acid battery self-discharges even when not hooked to anything. 10% per month is an average figure. Some more and some less. The more heavy-duty the battery the faster it discharges all on it's own (due to the extra antimony).
My 1998 Dodge van can last 6 - 8 weeks before it gets dead on it's own and it's been like that since new. Owner's manual says it must be started every 6 weeks or have the battery unhooked. I just leave a battery maintainer on it.
[Reply]  [No Email]
MarkB_MI
12-11-2012 17:41:00
75.198.32.244
I'm guessing you didn't have the battery fully charged when you parked it. There's a fair amount of battery drain on an '88 when it's parked, but a new battery shouldn't go dead in two months. Leave the charger on it for a couple of days and it should be fine.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
