Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Removing Ceramic Tile
George Marsh
12-10-2012 12:06:24
Dick,
My personal use, I use 1/2 inch cement board under my tile. There is a 1/4 inch backer board available. Have used it under tile. I was told not to put tile on wood, because wood moves too much with temp and moisture.
I put thin set under backer board or cement board and screw it down.
I don't like using large tile over wood sub floors, it will usually pop up or crack the tile.
Wood will flex when a heavy person walks on it, so I wouldn't go larger than 6x6.
To deal with elevation difference get you a piece of oak and make a transition piece. Done that many times. A few times I make the oak piece to match the elevation of the tile and grout to the oak. Or mill the oak to go over the tile.
George
Ultradog MN
12-10-2012 15:25:03
 Re: Removing Ceramic Tile in reply to George Marsh, 12-10-2012 12:06:24
Edit
This post was edited by Ultradog MN at 02:30:03 12/11/12.
George Marsh
12-10-2012 16:34:33
 Re: Removing Ceramic Tile in reply to Ultradog MN, 12-10-2012 15:25:03
Used thin set under cement board and backer board, never had a problem. That was 20 years ago.
Ultradog MN
12-10-2012 16:40:32
 Re: Removing Ceramic Tile in reply to George Marsh, 12-10-2012 16:34:33
Edit
This post was edited by Ultradog MN at 02:30:27 12/11/12.
George Marsh
12-10-2012 17:34:44
 Re: Removing Ceramic Tile in reply to Ultradog MN, 12-10-2012 16:40:32
Tearing out is not my problem. After I die, it may be the new owner's problem. I've done 5 rooms in my house and 4 rooms for my sister. Not one tile has popped, cracked, no grout failure. No plans to ever change tile either.
Ultradog MN
12-10-2012 17:47:50
 Re: Removing Ceramic Tile in reply to George Marsh, 12-10-2012 17:34:44
Edit
I'm going to have to do some soul searching on this.
This post was edited by Ultradog MN at 02:31:57 12/11/12.
George Marsh
12-10-2012 18:23:00
 Re: Removing Ceramic Tile in reply to Ultradog MN, 12-10-2012 17:47:50
I'm not going to care what anyone says about me when I'm dead. I only work for myself, so I only have one person to make happy. Also worked for my sister. I worked for food and a ticket to Florida where she lives.
I figure my floors will be there after a tornado, earth quake and who knows maybe a fire.
