Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Chain saw problem
12-04-2012 17:46:19
high adj 7/8 turn, low adj 1 turn but the vent valve was all messed up and I put one in from a weed eater that might be the problem, I have soaked that carb several times in carb cleaner, flushed with acetone and then blown out with air.
Idaho spud
12-04-2012 18:30:08
 Re: Chain saw problem in reply to Bigmarv1085, 12-04-2012 17:46:19
As one of the other guys mentioned, the fuel cap might not be venting right. After it quits ya if you open fuel cap and it blows gas back at ya it's not venting right. I have had saws that the ignition coil would put out too weak of spark after they got heated up. Normally the ignition is either good or bad but I have had them get weak after thay heat up. If it starts bogging down a quits ya, pull the plug and see if it has fire. If no fire, a bad ignition coil.
