Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Hydraulic Problem Solved.
Puddles
12-04-2012 09:46:46
From what I can see in your pictures on the other forum, you're gonna have structural problems where the hydraulic cylinder is tail hold on both ends. You have the C-channel going the weak way, I'll bet anything you'll need to brace them, at least with a V going back to the side frame. :wink:
Fawteen
12-04-2012 11:53:51
 Re: Hydraulic Problem Solved. in reply to Puddles, 12-04-2012 09:46:46
There ARE braces going from as low on the fixed mount of the cylinder as I could get them, going to the main frame about halfway forward, just above the axles.
Learned that lesson the first time I tried to lift the empty bed, even before it was decked.
I may box that rear member, or if you have a better way to reinforce it, let me know.
Puddles
12-04-2012 12:00:49
 Re: Hydraulic Problem Solved. in reply to Fawteen, 12-04-2012 11:53:51
Maybe something like this, try to use the same size / width / height material.
Stick welding
12-04-2012 22:11:12
 Re: Hydraulic Problem Solved. in reply to Puddles, 12-04-2012 12:00:49
Puddles, that's what I was trying to suggest but didn't have your computer savvy to show a pick. LoL I still think the pump may be turning too fast. I would put a tach. on it to check the RPM.
Fawteen
12-04-2012 12:21:18
This shows the bracing to the rear (fixed) end of the cylinder.
I like the idea of bracing that rear cross member on the subframe tho. I'll have to see what I can scrounge up for material.
After cleaning up the plumbing I loaded about of yard of wet compost on it, and dumped it okay.
Definitely going to have to re-gear it, it was ALL that 5.5 Honda wanted to lift that load.
Puddles
12-04-2012 13:18:48
 Re: Hydraulic Problem Solved. in reply to Fawteen, 12-04-2012 12:21:18
It might just be the picture, but it looks like that box tube is already bowed?
Fawteen
12-04-2012 13:40:51
 Re: Hydraulic Problem Solved. in reply to Puddles, 12-04-2012 13:18:48
Camera distortion.
The push point on the dump frame has been triangulated since that picture was taken.
Next time I have the bed tilted up I'll take some more pictures.
paul
12-04-2012 10:59:10
I can't weld worth a darn, but that would sound right to me, Puddles.
--->Paul
DBer60!
12-04-2012 20:41:20
 Re: Hydraulic Problem Solved. in reply to paul, 12-04-2012 10:59:10
If the gate valve is just a plain water (plumbing)valve it can burst due to more pressure than it is rated to handle,i have had it happen.BE CAREFUL DON
