TractorLinks.com
Tool Talk Discussion Forum
Re: Puddles
Puddles
11-30-2012 17:26:34
Hi Al! I aways like Hobart's Fabshield 21-B. It will run beautifully in all positions. Next would be Lincoln's NR-212. Both are child's play to run.
algar
12-01-2012 21:17:43
 Re: Puddles in reply to Puddles, 11-30-2012 17:26:34
Would you use NR-212 on code work structural?
I use NR-232 for out of position .lots of slag to get out of the way,looks like gas shielded flux cor low spatter.
NS-3m 5/64 to.120 for flat work awesome lbs per hr.
al
Stick welding
12-02-2012 00:19:00
 Re: Puddles in reply to algar, 12-01-2012 21:17:43
I ran some 3/32" NS3M. If you really turn it up you can burn a big spool in about 2 hours. Welds are super smooth unless you get arc blow. Then it's ugly.
algar
12-02-2012 07:41:26
 Re: Puddles in reply to Stick welding, 12-02-2012 00:19:00
Yes the slag looks like sub arc. We have 5/64,3/32 that we use most. and .120 when we have something that will take the heat.
I did 4 35 ton haul truck floors and side this summer with 3/32 NS3m and the verts with 1/16 233
