TractorLinks.com
Tool Talk Discussion Forum
Re: stuck post hole auger
Dell (WA)
11-30-2012 10:31:18
Don........since I didn't have an auger for my 8N, I rented a Yammabottadeere with post hole digger. I was doing great digging holes for new fence line ...until... my front wheels were 3-ft in the air!!! I could NOT raise my digger!!! I managed to gitt some wood cribbing under the front axle and then I could un-bolt the auger. I then moved the tractor outta the way so I could "pipe-wrench" the auger. NO LUCK. I then realize I'd haffta DIG the auger outta the ground. It had "screwed" itself into BIG tree ROOT. I ended up having a 3-ft post hole instead of nice 6"-holes. ........holey Dell
P.S.........what I've never figgered out, you dig a 6"-hole and putta 6"-post in it and still don't have enuff dirt to tamp the post tite........2nd point, NEVER CEMENT yer posts, the cement collects WATER and ROTS yer treated post off
Brad Buchanan
12-01-2012 08:15:49
 Re: stuck post hole auger in reply to Dell (WA), 11-30-2012 10:31:18
Interesting opinion.
Auger hole, shovelfull of pea gravel, set post, 1/2 or more bag of sackrete and grade over.
Have removed posts that have been in the ground 15 years and wood is perfectly sound.
Brad (yer signpost settin' guy)
Bendee
11-30-2012 22:58:59
You will get rot if you concrete underneath the post and create a reservoir.
thurlow
11-30-2012 15:18:52
We've augered our share under tree roots, etc. Never seen one that we couldn't back out with a 3 ft pipe wrench.....with the digger still on the tractor. I eventually bought a 3-point hitch hydraulic digger; paid big bucks, but as many holes as we dug, it was worth it. As far as the soil going back in the hole; it had to do with the phase of the moon or the amount of moisture in the soil or........SOMETHING; sometimes there wasn't ENOUGH soil and sometimes there was TOO much.
chevytaHOE5674
11-30-2012 11:26:35
I've noticed that too. Fill the hole up with a post and shove all the same dirt back in and you are still short.
