Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Topic: Re: MIG wire feed
[Show Entire Topic]  [Return to Forum]
Stick welding
11-29-2012 22:19:01
96.53.210.246
First thing to check is the roll of wire itself. If it's not wound properly or has come loose on the spool it will not feed properly. DON'T lube the wire spool spindle!!! The wire has to have some drag so the remaining wire doesn't start unspooling as soon as you stop welding. If the wire has become loose on the spool, it's a good possibility the whole spool will be useless for welding unless you cut off the loose wire while keeping the remaining wire tight. You may be able to adjust the brake for the spool and I've also seen it where the brake would tighten as the spool turned. You could also have a section of deformed wire on the spool from when it was made. I've seen that before too. Try a new contact tip first.
60 pounds of .023 MIG wire is 519,120 inches of wire. That's a little bit more than light use so you may need a new liner. I wouldn't use wire lube but you can get pre-lubed pads that have a very, very small amount of lube on them. Also don't over tighten the drive rolls as it will deform the wire and cause it to get hung up in the liner or contact tip. It will also cause the wire to flake off more little bits of copper that can plug the liner.
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
