Hi Al! I aways like Hobart's Fabshield 21-B. It will run beautifully in all positions. Next would be Lincoln's NR-212. Both are child's play to run.
Would you use NR-212 on code work structural?
I use NR-232 for out of position .lots of slag to get out of the way,looks like gas shielded flux cor low spatter.
NS-3m 5/64 to.120 for flat work awesome lbs per hr.
al
I ran some 3/32" NS3M. If you really turn it up you can burn a big spool in about 2 hours. Welds are super smooth unless you get arc blow. Then it's ugly.
(quoted from post at 22:17:43 12/01/12)
Al here on the west coast the structural welding world got turned on it's ear after the Northridge earthquake in California. Soon after about all you seen specified was NR-232, or Coreshield 8. Latter Lincoln came out with NR-233 which is a little more user friendly. All this happened after I was in management, all I was doing at the time was supervising welding crews, not welding myself.
I have been on jobs welding pre-cast concrete panels to steel beams where we used NS-3M. Back in the 80s I worked on several Navy projects where they would only accept NR-203.
So when I suggested 21-B, and NR-212 I thought you wanted a good general fab wire, not looking for a wire for code work. :wink:
That's ok,some stuff get's lost in my typing.
I help out at a quarry operation when I am laid off and they use alot of Inner. Their family graduated to this after having a welding shop that did alot of equip repair,track shop etc..They used the big NS 3M on d-8 and 9 track grousers. I got them using 232-233 cause 203m1% wasn't very good to work with.
They bought new surplus bulk and it was around for years.
Yes the slag looks like sub arc. We have 5/64,3/32 that we use most. and .120 when we have something that will take the heat.
I did 4 35 ton haul truck floors and side this summer with 3/32 NS3m and the verts with 1/16 233
