TractorLinks.com
Tool Talk Discussion Forum
Re: Copper water pipe soldering
husker44a
11-28-2012 19:42:30
PEX is the only way to go. I replaced a water softener the other day and used the PEX push on fittings. Kinda pricey but guarenteed not to leak. Measure twice. Cut once. Very simple to use. Sharkbite fittings are in code.
wgm
11-29-2012 01:59:26
 Re: Copper water pipe soldering in reply to husker44a, 11-28-2012 19:42:30
PEX is a joke
C.R.
11-29-2012 02:06:13
 Re: Copper water pipe soldering in reply to wgm, 11-29-2012 01:59:26
Why do you think PEX is a joke?
George Marsh
11-29-2012 04:30:32
 Re: Copper water pipe soldering in reply to C.R., 11-29-2012 02:06:13
PEX is very expensive. I tried to take one fitting apart after a few years, O-ring was damaged. Another fitting went from pex to copper, couldn't stop it from leaking. I use cpvc instead.
Can't come up with a good reason to use pex. It's like quest, a joke.
Stephen Newell
11-29-2012 03:38:48
I think anyone that has lived with quest plumbing is going to be apprehensive about another garden hose plumbing. I for one don't live where the water is acidic so I'm going to stay with copper.
wile E
11-29-2012 02:16:39
I also have a hard time plumbing a house with PEX. I used all copper line, soldered, the real way to do it. I cannot (would not) put plastic line in a wall where it could be punctured by a finishing nail. (a fricken mess) I would use hard PVC before I used flexy plastic poly ethlene or poly urethate tube. I am not claiming to be an expert, just trying to think with common sense. Also the push to connect fittings are nice........Only if they are in view, never behind a wall. I did use compression brass fittings for all my sinks and toilets when I built a home many years ago.
chevytaHOE5674
11-29-2012 04:16:23
 Re: Copper water pipe soldering in reply to wile E, 11-29-2012 02:16:39
You don't think that a nail can pierce copper? Copper is pretty soft and hit just right a nail will easily go through it. I've personally seen it happen.
showcrop
11-29-2012 04:44:13
 Re: Copper water pipe soldering in reply to chevytaHOE5674, 11-29-2012 04:16:23
When you have acidic water, and I can think of three municipal supplies in the area off the top of my head, copper makes no sense. I knew of a good sized fifteen year old nursing home that had a guy pretty much full time pulling out sections of copper and replacing them. He could not go systematically through it because he kept getting called to emergency leaks.
Butch(OH)
11-29-2012 03:56:12
I am no expert either but we used Zurn pex and crimp ring fittings to plumb up our OWB 6 years ago and have had zero problems so when the plumber reccmended pex to replumb a rental this past spring we said go ahead, time will tell. People say CPVC is junk too but when I was close to broke and had to replumb my home I had to use it,, that was 30 years ago and it is still in service, never a leak, never a problem.
