TractorLinks.com
Tool Talk Discussion Forum
Might give the Machinists a chuckle (pics)
Brad Buchanan
11-26-2012 19:29:15
Hey everybody.
I set up a pump to fuel some small heaters and due to poor planning on my part the nozzle didn't fit the hole in the tanks!
It was the holiday weekend and I didn't have any luck finding an adapter to do the job.
Finally I got disgusted and pulled out some 35mm hex aluminum bar that I had and went to work.
A carbide blade on the table saw sliced off a 1 1/4" section and I set up the drill press with a 13/16" hole saw.
I removed the 'plug' and drilled and filed 'till I had the hole to 7/16".
I welded the plug into the end of the nozzle and after some filing and shaping it actually works!
I will never be mistaken for a real machinist I fear.
Brad
671DKS
11-28-2012 20:47:50
 Re: Might give the Machinists a chuckle (pics) in reply to Brad Buchanan, 11-26-2012 19:29:15
I'm sitting here trying to figure out what to use the leftover hex piece for now...
JRSutton
11-27-2012 11:20:34
You know, there IS a much easier way.
You could have used a chain saw to cut off a spare chunk of steel from your wife's car, melted it down and just cast that little sleeve.
Steve in VA
11-27-2012 07:47:25
"If we don't have the part, we'll make the part.
If we don't have the tools to make the part, we'll make the tools to make the part."
JMOR
11-26-2012 22:26:41
 Re: Might give the Machinists a chuckle (pics) in reply to to_many_irons, 11-26-2012 19:29:15
Quoting Removed, click Modern View to seeBad part is that back when unleaded gas first came around, all the auto supply stores sold a stepped plastic sleeve that slipped over a big leaded nozzle so that it would fit into the small filler hole on unleaded-only cars. Probably costs less than 50 cents. Can't find my old one & never see them in stores anymore. Probably against some law now.
scotc
11-27-2012 21:32:38
 Re: Might give the Machinists a chuckle (pics) in reply to JMOR, 11-26-2012 22:26:41
We just stuck an old milker inflation on the end of the gas nozzle.
BOB HAWBECKER
11-26-2012 20:33:24
he just wanted to play with his toys
ya did good!
oh the saw thing we used to turn saw blade around and cut alum. siding in the younger days.
Justin SE IOWA
11-26-2012 19:54:19
Thats awesome! Nothing like thinking outside the box!
Ted in NE-OH
11-26-2012 19:39:34
Wouldn't a funnel work?
Dave Sherburne NY
11-27-2012 06:42:10
 Re: Might give the Machinists a chuckle (pics) in reply to Ted in NE-OH, 11-26-2012 19:39:34
Anybody can do it the easy way.
casenut1
11-26-2012 21:37:26
that's to simple.
danofarming
11-27-2012 18:50:41
 Re: Might give the Machinists a chuckle (pics) in reply to casenut1, 11-26-2012 21:37:26
I remember a joke about the US making the worlds smallest drill bit. sent it to the russians, they drilled a hole in it and sent it back!
