Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Topic: Re: Question for you reloaders (gun)
[Show Entire Topic]  [Return to Forum]
old
11-25-2012 10:23:26
209.86.226.34
I have tried all the set up things as per the instructions and even tried a 3006 die I have and can not get the brass it size correctly but use a 3006 brass and it does size as it should. I got this 308 die with the reloader so who knows what may have been done to it
[Reply]   [No Email]
MarkB_MI
11-25-2012 15:14:12
75.219.136.18
 Re: Question for you reloaders (gun) in reply to old, 11-25-2012 10:23:26
You cannot size 308 brass with a 30-06 die because the die will bottom out before the case neck is sized.
You CAN neck size 30-06 brass in a CONVENTIONAL 308 die. But it seems apparent that you have a collet die, not a conventional die.
If you still believe you have a conventional die, simply remove the expander and size a case. If you can insert a bullet into the neck, then either the sizer is bad or your brass has unusually thin necks. You shouldn't have thin necks with once-fired brass, but with brass of unknown origin there's a possibility the case necks have been reamed or turned to accommodate an undersize chamber. (Turning case necks is SOP for benchrest shooters.) I find it hard to believe your sizing die is bad, but after all we ARE talking about a Lee "Precision" product.
Just so we're on the same page, a conventional sizing die sizes the case neck in two operations: During the downstroke, the sizer enters the oversize case neck, which is then squeezed undersize by the die body. Then, on the upstroke the expander is pulled through the now undersize case neck, expanding it to the appropriate i.d.
A collet die sizes by squeezing the case neck between the body and mandrel. Naturally the case neck will spring back after sizing, so the mandrel has to be a bit undersize.
It seems you're not the only one to have problems with the Lee Wonder T*rd Collet Die; see the link below:
[Reply]  [No Email]
old
11-25-2012 18:16:28
209.86.226.27
 Re: Question for you reloaders (gun) in reply to MarkB_MI, 11-25-2012 15:14:12
This brass is once fired as in shot only one time Winchester brass. I have tried it with the expander and with out the expander and still not right as in bullet almost falls out. Thinking about try to do a little 30/30 brass and see if I run into the same thing. Ya 30/30 is a die set I want to get but have not since the last set I had was stolen form me by a guy who said hey let me use your die then he booked with it and have not seen him in 15 plus years
[Reply]  [No Email]
kevinj54
11-25-2012 11:05:01
50.36.191.42
So if you run a o6 into the 308 die it sizes the neck properly???
That take you back to thin or hardened brass for the 308
[Reply]  [No Email]
old
11-25-2012 18:23:03
209.86.226.27
 Re: Question for you reloaders (gun) in reply to kevinj54, 11-25-2012 11:05:01
Not sure I tried the 06 in the 308 die guess I will double check that to be sure and also will try a few 30/30 in the 308 die and see what happens. This brass is Winchester once fired brass so maybe this stuff is new junk brass??
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
