Do you sharpen your own tools?
Dick2
I started sharpening our tools when I was a sophomore in high school. Use whatever it takes. I've found that my rotary tool with a cut-off disc works real good on carbide saw teeth that are too hard to file.
Used the rotary tool to sharpen a couple Forstner bits this morning.
I would sure like to find a circular saw (skillsaw, table saw) sharpening service. Got a lot of blades that could provide useful service if they were sharpened.
Most everything else I do myself. Axes, knives, chainsaws, sicklebars,etc.
You can sharpen your saw blades on a bench grinder. just need to touch the backside of the tooth on the wheel.
I have been sharpening my my own tools as mentioned above. If I can't sharpen it usually buy a new one.
(quoted from post at 17:04:07 11/18/12) I would sure like to find a circular saw (skillsaw, table saw) sharpening service. Got a lot of blades that could provide useful service if they were sharpened.
Have you tried Tubergen in Grand Rapids???? They have done very good work for me including my buzzsaw blade.
I bought one of HF's saw blade sharping machines. Couldn't get it to work so went back to using the rotary tool with a small cutoff wheel.
I use a Dremal with a cutoff disk/wheel to sharpen some tools/cutters in my tool shop. Like you, I use what ever I have at hand to get the job done.
The Belsaw Sharp-all is the best circular sharpening machine and you can hang out a shingle and make money doing it.
I taught Mommy to do it and she liked to do it cause she stuck with it for a long time.
You can buy a foreign diamond grinding wheel for cheap and do the Tungsten Carbide tipped blades just as well.
If you got one for sale, let me know by email.
ohfred41
I learned in highschool too - my dad taught me.
My dad was good at a lot of things, but unfortunately, sharpening tools was NOT one of them.
Later in life I learned on my own that a bench grinder was not the ideal way to sharpen a wood chisel.
I'll never forget the first time I finally figured it out - sharpening one of his old hand planes. I did have to grind it first to get the angle right after so many bad attempts by him - then honed it - stropped it - and actually got it so I could easily shave hairs off my arm with it.
I never realized you could get a tool that sharp without "fancy equipment" (as my dad always told me we'd need). I always thought shaving hair on your arm was some kind of exageration.
Just wish I had figured it out while he was alive. It's really simple once you "get it", but he just never learned how to do it right.
He always appreciated a sharp tool, but for him, that meant buying a new one, and that's as good as it would ever be.
I've learned that the difference between a plane or a chisel sharpened properly with care, and one that's "close enough" is hard to even put into words.
He really would have loved using a truly sharp plane. Wish I figured it out earlier - he was always so frustrated by dull tools.
