Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Topic: gib key puller
[Return to Forum]
756puller
11-13-2012 17:59:22
96.31.184.142
anybody have a good way to pull those god awful gib keys out?
[Reply]   [No Email]
Tech 7
11-15-2012 11:15:46
206.47.90.66
Re: gib key puller in reply to 756puller, 11-13-2012 17:59:22
I remember fighting those beggars when we had a New Holland combine. Local dealer was good to loan us those "Russian Punches" as I used to call them, to quickly and easily cut the heads off of the gib keys. Then as others said,the welder came into play. Don't miss them or the NH combines at all.
  [Reply]  [No Email]
RodInNs
11-15-2012 11:44:45
216.118.158.123
Re: gib key puller in reply to Tech 7, 11-15-2012 11:15:46
I kinda like the Gib key. I know they're devils to remove... but I've never seen on that was properly fitted come loose, regardless of the circumstances.... I can't say the same about straight keys.
Rod
  [Reply]  [No Email]
RodInNS
11-14-2012 18:21:31
216.118.158.123
Scot is showing the correct tool... as far as it goes.
I usually weld a piece of 1/2" threaded rod to the head of the key and slide a deep 1/2" socket of an appropriate size over the rod and key head. Then put some washer and a nut on and torque it up... then drive the sprocket/sheave away from the key. The bar shown is supposed to follow the same principle in that you tension it up and drive the sprocket away... when it works. Usually it bends the head of the key over.... or breaks it off. Then you start welding. Basics... drive the sprocket away as you can't pull the key. You just want to hold the key while driving the sprocket away.
Now... if ya got the sprcket driven hard against the bearing... you've got my pity. That will take a lot of pulling and welding.
Rod
  [Reply]  [No Email]
Scott 730
11-14-2012 15:27:55
75.168.207.114
Re: gib key puller in reply to JDseller, 11-13-2012 17:59:22
Here is the right way to do it.
www.hitnmiss.com
  [Reply]  [No Email]
VernMI
11-14-2012 04:27:11
209.86.226.57
I drilled and tapped the end of the gib key and used a slide puller. It is best to first push the hub onto the shaft slightly to help break it free.
  [Reply]  [No Email]
Retired Farmer
11-13-2012 20:34:20
207.200.116.12
First off you are supposed to drive the hub on the shaft a little ways before you pull the key, just hope it isn't rusted on. I made a puller using a Snap On slide hammer. Used a couple of fine thread nuts welded together that screwed on the slide rod and welded a three quarter nut onto the end of those. Put the hole in the nut over the projection on the key and pulled them right out.
  [Reply]  [No Email]
JerryD
11-13-2012 19:41:08
69.151.187.81
Go to GOOGLE IMAGES and type in "gib key puller"
There are a lot of good ideas there.
  [Reply]  [No Email]
Berne/MA
11-13-2012 18:04:43
67.142.166.27
Make a slide hammer and weld it to a pair of vice-grips.
  [Reply]  [No Email]
Diydave
11-14-2012 05:20:29
96.244.153.238
Re: gib key puller in reply to Berne/MA, 11-13-2012 18:04:43
HF, and others sell a slide hammer kit, that has all the adapters, to attach a slide hammer, to vice grips, gear puller, etc. One of the handiest set-ups around, IMHO!
  [Reply]  [No Email]
JMS./MN
11-13-2012 22:06:12
209.237.125.241
I used my OTC slide hammer on vice grips. IIRC, threads did not match but I removed the VG adjusting bolt and welded the proper nut in its place. Used it only once, slide hammer still works with original tip, internal bearing tool.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
