Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Topic: Re: inverter watts
[Show Entire Topic]  [Return to Forum]
John T
11-11-2012 05:22:39
216.249.82.117
In line with what JD noted, if you first use a 12 VDC to 120 VAC INVERTER and then plug your DeWalt 120 VAC to 18 VDC Charger, YOU HAVE WASTED SOME ENERGY in the form of heat losses since none of those devices are 100% efficient. But ifffffffffffff you can buy a 12 VDC to 18 VDC charger (it still has to have some inefficient electronics for 12/18 conversion) you would be better off as far as saving the trucks battery energy...
So ifffffffff they make a plug into cigarette outlet charger to charge 18 volt batteries (still needs some electronics to do that) ??????????????????? Id go that route, however, if not or exepesive or hard to find, its true a cheap plug in Inverter in the 200 to 400 watt range (around $40 or so) would be quick n simple into which you plug your regular DeWalt 120/18 charger...........Plus the Inverter is there handy to charge youre regular 120 VAC cell phone and laptop etc if you dont have a 12 volt charger device?????
Lots of choices, do some shopping and consider youre needs, heck the 400 watt 12 VDC/120 VAC regular plug in Inverter would be simple n handy to have, its what I use in the RV so I can watch TV or charge my devices etc etc when Im dry camping with no hook ups
John T THANKS VETERANS
[Reply]   [No Email]
LJD
11-11-2012 06:02:34
75.194.7.205
 Re: inverter watts in reply to John T, 11-11-2012 05:22:39
Inverters really are a "crap shoot" unless high-end and power certified. My experience with charging 18 volt power tools with inverters has been as already stated. No major issues with any of the small cheap inverters. Just a little slower. Same for cell phones.
But . . here's one for you. I recently got a so-called Ramsond Sunray "true sine wave" 3000 watt more-pricey inverter. I had to in order to pass building inspecting since a mod-wave will not run smoke alarms and GFIC outlets properly. An inverter that can be hard-wired is also necessary for inspection. Guess what? It will NOT run my Dewalt or Ryobi 18 volt chargers. Yet, all my cheap mod-wave inverters do the job just fine. If just goes to show that very few of them make a true sine-wave unless you spend $1000s on a unit. I checked AC output with a RMS volt meter and this "true sine-wave" unit is only putting out 109 volts AC. All my other inverters put out 114-120 VAC when read with RMS. If read with a non RMS el-cheapo voltmeter, the mod-waves only read around 85 volts (but work fine).
[Reply]  [No Email]
John T
11-11-2012 06:18:02
216.249.82.117
 Re: inverter watts in reply to LJD, 11-11-2012 06:02:34
I hear and believe what youre saying, I'm just too rusty on "electronics" to have much input as I was more into Secondary AC Distribution in my later work years and I stopped that back in 91. All I know is the 400 watt Cobra and other off the shelf cheaper brands in the RV work good enough to charge my cell phone, run a small TV and run the laptop and thats all I need.
As always, fun sparky chattin with ya...
John T
[Reply]  [No Email]
LJD
11-11-2012 06:28:36
75.194.7.205
 Re: inverter watts in reply to John T, 11-11-2012 06:18:02
There IS no way to keep up unless you actually use these different units. You certainly cannot tell by reading their advertised specs.
Yes, I've got many cheap Cobra, Vectors, Harbor Freight, Duracell, AIMs, etc. and all work fine for most things. None will run a GFIC outlet of a smoke alarm though. That's an issue when wiring a low voltage house and trying to pass inspection.
So, I HAD to buy this $800 "true sine wave" inverter to pass inspection. My 4000 watt hard-wired Trace/Xantrex would not pass since it cannot run the smoke alarms and GFICs. Note that this new unit runs the required stuff perfectly but will NOT run an 18 volt charger. It comes on but never shuts off. I left one on for two full days. Then stuck it on a cheap mod-wave Vector and it got done in 15 minutes.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
