Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Stihl 029 unwanted chain tightening
jack345
11-10-2012 20:42:27
On bottom of saw you will see a hole for adjusting oil flow-arrow points to direction of max flow.
1.Adjust for max flow (check manual)
2.With bar and chain off saw start saw rev up and and you should have oil flow.If not check oil pump.
3.Make sure clutch drum is in place when running engine.Clutch drum drives oil pump ( the long wire fits in the notch on clutch drum which drives oil pump.Oil pumps do go bad.
4.If you have oil the bar oil port hole could be plugged.Clean.
