Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Diesel Fuel Tank converted to Propane Tank?
JMS./MN
11-07-2012 14:56:57
Propane fuel is stored at relatively high pressure. Your diesel fuel tank is not a pressure vessel- just atmospheric. So, no.
Emily
11-07-2012 15:02:49
 Re: Diesel Fuel Tank converted to Propane Tank? in reply to JMS./MN, 11-07-2012 14:56:57
Thank you. That makes sense.
What about the fuel line that is installed underground that has had diesel running through it? Any idea if we have to rip that up and instal one designed only for propane? Or is there a way to clean out the fuel line and safely use propane in it?
Thanks!
JMS./MN
11-07-2012 19:21:21
 Re: Diesel Fuel Tank converted to Propane Tank? in reply to Emily, 11-07-2012 15:02:49
I have no idea what the underground fuel line is............maybe it is copper, like propane lines are. The line is not the issue- the tank is. Plus, YOU are, your spouse, and family- that is most important! Bottom line, YOU need to contact a supplier, and installer, to handle your propane issues. It is nothing to be handled by an amateur!
Emily
11-08-2012 10:55:49
 Re: Diesel Fuel Tank converted to Propane Tank? in reply to JMS./MN, 11-07-2012 19:21:21
I realize that sir...thank you.
Propane
11-07-2012 15:20:32
You need a completely different set up for propane. Propane is actually boiling inside the tank at about -50 degs. and that's what causes the pressure to build up to around 250 PSI. You want to have a certified tank and the right line to the heater. Talk to your propane supplier or the heater manufacturer.
