Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
What is it?
Tony in SD
11-07-2012 01:37:52
What is it? Its about 20 inches long. A friend of mine gave it to me and I have no idea what it is used for. Thanks in advance for the help.
Tony
Tony in SD
11-07-2012 16:20:12
 Re: What is it? in reply to Tony in SD, 11-07-2012 01:37:52
Thanks greygoat & lenND. Now I know
LenND
11-07-2012 12:37:24
Greygoat is right. It is or was used to change or pack the waste in the railcar wheel journals. In fact I have the one I used fifty some years ago. They finally went to roller bearings and ended that.
greygoat
11-07-2012 09:24:07
You're all wrong...It's a PACKING TOOL for use
on old railroad cars that had friction bearings.
The old, non roller bearing cars, had Journal
BOX's, (thus the term HOT BOX, when they overheated, and caught on fire)That had a thick pad of packing material, that looked like
toweling, or felt. The box held about a gallon of
"Journal Box Oil". The pad rubbed the bottom of
the axle to lubricate it as it rolled. On top of
the axle sat the Journal bearing, about 6 x 11
or 7 x 12 with about a 1 inch thick babbit
section that sat on the axle, and had about a
2 inch thick brass top section. The weight of the
car sat on the journal box, which sat on the journal bearing, which sat on the axle. Journal
box's had to be inspected every 500 miles by
"Carmen", and re oiled as needed. The tool has
a spur on it that pulled open the journal box
door, for inspection, the "spoon" part, on the
end was for adjusting-removing-replaceing the
packing. A car mans job, in the pre roller
bearing days was very dangerous, and many got
killed, or legs cut off, while oiling cars in
railroad yards , by moving cars!
I've oiled thousands of cars !
Diydave
11-07-2012 16:46:58
 Re: What is it? in reply to greygoat, 11-07-2012 09:24:07
Thanks, Greygoat, I always learn something on here, and that was today's lesson!
Mike Groom
11-07-2012 07:12:53
I think Dave is right,a grate lifter for coals in a stove or fireplace.
PAGlenn
11-07-2012 06:15:10
A large skelton key for a really large thick door
Diydave
11-07-2012 04:20:12
Combination klinker remover/grate shaker from an old coal stove/furnace?
Roy in UK
11-07-2012 03:47:23
I sure would like to see the can of spam that you open with that key!
60 acre hillside
11-07-2012 02:58:03
Looks like a balling gun used to administer a pill in cattle
