After reading mutiple posts on this subject I have some questions.
I am installing a 60 amp sub panel. This panel is adjacent to the main panel. In the same building not remote.
Here are the qusetions:
1. Should it be connected with metal or plastic conduit?
2. If connected with metal do you need a ground wire?
3. What gauge wire? This is only at most 2 feet of wire.
4. Does it need to have the neutral bonded?
5. Run 3 or 4 wires? That is to say does it need the ground wire?
6. Had an electrician here today and he said " run 3 wires and bond the neutral. Is he correct?
Thanks for everyones help in advance.
