TractorLinks.com
Tool Talk Discussion Forum
Re: Sub Panel Question
Bus Driver
11-06-2012 09:42:26
1. Should it be connected with metal or plastic conduit?
Not necessary in most jurisdictions. SER cable is one type cable that can be used. 2. If connected with metal do you need a ground wire?
Either that or grounding bushings on the conduit. 3. What gauge wire? This is only at most 2 feet of wire.
Not smaller than #6.
4. Does it need to have the neutral bonded?
Absolutely not-- if you understand the meaning of bonding.
5. Run 3 or 4 wires? That is to say does it need the ground wire?
The SER takes care of that. 6. Had an electrician here today and he said " run 3 wires and bond the neutral. Is he correct?
NO!
