TractorLinks.com
Tool Talk Discussion Forum
Re: Bulldozer battery?
LJD
11-05-2012 14:11:07
I can't think of any reason not to use it. I don't believe that CCA figure though. That's probably that silly CA figure. Many 8D batteries are rated around 1100 cold-cranking-amps (CCA). The most expensive that I know of are rated 1450 CCA. 8D is about the twice the size of a BCI type 78 but almost 3" taller. 8D will have near 3 times the reserve capacity (RC) and amp-hours (AH) of one type 78.
With flooded lead-acid batteries the actual weight will tell you the story.
8D rated 1100 CCA weighs 117 lbs. wet.
8D rated 1450 CCA weighs 134 lbs. wet.
78 rated 750 CCA weighs 36 lbs. wet.
78 rated 950 CCA weighs 44 lbs. wet.
Brad Buchanan
11-06-2012 08:38:10
 Re: Bulldozer battery? in reply to LJD, 11-05-2012 14:11:07
You guys were completely right!
I looked it up and the cca was 1400. The ca was 1700.
I think I am going to try this battery and see how it performs. The next question is how big do the cables have to be. The longest run should be 7 ft. more or less. I was thinking about 2 gauge stranded copper.
Brad
buickanddeere
11-06-2012 08:59:43
 Re: Bulldozer battery? in reply to Brad Buchanan, 11-06-2012 08:38:10
Must have been a typo, you intended 2/00 or two aught. Bolt on clamps won't work either . Must be HD soldered or swagged clamps.
