| Tool Talk Discussion Forum |
Topic: Re: Onan generator mocroquite 4000
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Matt S Illinios
10-31-2012 07:25:02
69.174.58.156
Can't put it on a bench. Generator mounted on top of RV trailer. The code is "36" in which is out of gas, change air filter, clean/change plug. Can you give more details about the "fuel Cutoff" in carb? I am going to try and clean it as well tonight. Thanks Matt |
| jackinok
10-31-2012 08:53:38
162.58.82.136
Re: Onan generator mocroquite 4000 in reply to Matt S Illinios, 10-31-2012 07:25:02
| nearly all the modern gensets have a plunger type affair in bottom or side of carb thats electricaly controlled. usualy a single wire to it.its purpose is to cut off fuel flow in case of accident,emergencies,fire etc.basicaly to stop engine from pumping fuel into a fire or something of that nature.they normally dont shut off fuel to the engine persay,but block the main jet passages in carb. this gives a much faster shutdown since carb doesnt have to run out of fuel in bowl.in your onan carb ,if i recall on your model correctly its in the bottm of carb, has a single white wire to it.THAT for all intent and purposes is the main jet in your carb and if its closed,engine runs out of fuel in just a second.if your carb is blocked up very often ,( more often than not) unscrewing this will allow you to pullit out,and carb bowl will drop off.once its in your hand main jet passages will be in the tube attached to the end of solenoid ,and thats basically all the jets/orifices in the carb.clean bowl of course,and clean the orifices on solenoid good. before reinstalling spray some carb cleaner up into body of carb where tube goes in,because its common for bits of orings to get lodged there.make sure orings are good on solenoid and reinstall. to check power,use a voltmeter and check voltage at white wire and body of genset,should have voltage with switch held in start position(engine cranking).if voltage goes away as soon as engine starts,you most likely have either a exiter voltage problem,or a control board. if voltage stays and engine dies, either you have a problem with the plunger type solenoid itself,or a fuel delivery problem. (note) they WONT seem to pump much fuel when engine is cranking,simply because they are cranking at maybe 100-200 rpms,once engine starts its running several times that and it will pump far more. if you question fuel delivery system up to the carb simply gravity feed your fuel directly into carb from a safe source and bypass it all. if engine runs you know you have a fuel or fuel delivery problem. first thing i would do is try some fresh fuel if it were mine. if i recall right exciter voltage fault code is 33 (going by a old mans memory here so dont trust that too far),so that means at least the control board says you have it.once its past that point fault codes wont show a problem so also check for a broken or loose/corroded connection between there and carb. any fault basicaly thats not found electrically most likely defaults to 36 or a fuel problem. if engine wont run with no electrical faults thats the next most logical step,but fault codes wont show up if the electrical problem is past the point where voltage is tested if that makes any sense. hope this helps. I dont think ive ever seen a genset on the roof,must be a new thing they are doing.lokks to me as if that would amplify the noise a genset makes sort of like being inside a drum. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
