TractorLinks.com
Tool Talk Discussion Forum
Re: Metal Cut-off saw Recommendations
fergienewbee
10-30-2012 01:50:15
Thanks, all. I might try Old's idea.
Larry
bg/mo
10-30-2012 17:19:51
 Re: Metal Cut-off saw Recommendations in reply to fergienewbee, 10-30-2012 01:50:15
Get a chop saw it will cut better and safer, the circular saw ideal is not for pipe or anything thicker than sheet metal.
dave2
10-30-2012 03:03:49
Yea, or if you have a disc grinder, you may find at walmart or HD the little frame they clamp in to use them to chop (same principal as the little drill press frames). I've used dad's Ridgid tubing cutter to cut off shotgun and rifle barrels and cot 1 1/4 inch steel bar and it worked real slick also....
