Topic: Converting overhead fuel barrel to pump style
[Return to Forum]
| Author |
[Modern View]
| sflem849
10-27-2012 18:41:37
69.197.84.39
Has anyone converted an overhead fuel barrel to a pump setup? I would guess you need to weld feet on it and cut a hole in the top for the pump. Is there anything else to the job?
How do you cut and weld on the tank?
I was given these two overheads today. Don't be confused, there are two separtate setups pictured.
| Mo 1032D
10-27-2012 21:08:56
216.145.149.118
Re: Converting overhead fuel barrel to pump style in reply to sflem849, 10-27-2012 18:41:37
| Seen different ways to do what your planning, first you need to make sure you have no leaks in tanks. I made a fitting to pressurize tank to no more than 3 psi for 300 gal and 5psi for 500 gal. No since doing anything till you know tanks are good. As far as pumps I have seen them plumded into bottom bunge on tank, then braced with strap to top bunge as all you need to do is support pump. I would just shorten stands to your desired height. I have a few of my fuel customers that have done this, and havent had any problems. One of my customers put a post in the ground between his tanks and secured both pumps to it, worked out real nice that way. |
| Fixerupper
10-27-2012 19:40:24
100.42.82.164
| I agree with Jim. Welding isn't wise. Most fuel barrels have two 2" bungs on the top unless it's a real old one. If there is only one bung the pump will have to be lifted out for filling which is a little unhandy. I suppose you could put a tee on the fill bung, if there's only one, with a street el sticking out the side. Pump goes in from the top and you fill through the street el. It's not real conventional and you might have to get a longer suction pipe but you won't blow yourself up that way. Jim |
| Jim in MN
10-27-2012 18:58:02
98.132.220.48
| You could avoid welding on the tank by making the stands shorter. The fill cap should screw off. Install your pump there. Welding on tanks is risky business. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
