Topic: Re: Super C engine racing
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| mkirsch
10-24-2012 11:17:20
64.80.110.74
This isn't something you can adjust away. Like old says, they don't go out of adjustment just sitting.
I second trying to move the carburetor linkage as a test. It should move freely when the tractor isn't running. It should move then snap right back when the tractor is running,
As long as the linkages are free, a racing engine means the internal spring inside the governor has broken. It is not a difficult fix, but you do need to remove the governor housing.
There are six bolts holding the governor housing to the engine, one cotter key holding the throttle lever rod, and one more cotter key and pin holding the carburetor linkage.
Support the housing and don't let it fall. The timing gear and governor weights will stay in the engine unless you go totally caveman getting the housing out. Normally there's nothing wrong with the gear or weights.
The housing WILL come out without taking off the radiator. It's a little tight, but if you hold your tongue just right it will come right out. Just keep tipping and turning until you get it.
Once you get the housing off, you'll see a spring broken in two. You will need the OEM part from a CaseIH dealer to get the correct behavior from the governor. |
| 60 Acre Hillsode
10-26-2012 14:44:13
67.142.170.27
Re: Super C engine racing in reply to mkirsch, 10-24-2012 11:17:20
| I doubt it being that spring in the governor. That spring is moved by the throttle lever and if the spring is broken the throttle lever will not move the carburetor from idle. The one who posted to look to see if the shaft from the governor (enclosed in timing cover) is stuck. That is most likely the problem. I had a Cub to that and a lot of moving with a wrench and lots of penetrating oil got it freed up. The original problem was I installed a radiator with the overfloe tube being in the wrong place spewing water on the front timing cover. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
