| Tool Talk Discussion Forum |
Topic: Super C engine racing
[Return to Forum]
| Author |
[Modern View]
| ken19
10-24-2012 07:07:21
69.72.75.22
My 1953 Super C has been unused the past year (due to a job far from home). My meadow grass is of course now taller than me. Home for awhile and intending to do some bushogging I did some basic maintenance (oil, lube, gas, battery, etc.) on it then fired up the Super C. It started up at a very full throttle even though the throttle lever was back. Moving the throttle had no effect. In short, the engine is racing. I suspect something is wrong with the governor. The linkage from the throttle looks okay. I know very little about the governor concept. I see what looks like an adjusting nut and note there is a little wire seal on it. Should I break the seal and turn that nut? Someone told me there are magnets that spin inside the case. How long do those magnets last? Do I have a simple adjustment problem or is this a disassemble and repair issue? For the 20 years I have owned this unit I have had no major problems beyond flaking of the tire sidewalls. |
| gab
10-24-2012 18:02:46
50.103.37.243
Re: Super C engine racing in reply to ken19, 10-24-2012 07:07:21
| Throttle used to stick on my Super C in the winter. That was crud and moisture in the needle bearings on the long shaft across the frt on yhe gov. |
| 60 acre hillside
10-26-2012 16:35:42
67.142.170.21
Re: Super C engine racing in reply to gab, 10-24-2012 18:02:46
| That is most likely. See my post below |
| cd1
10-24-2012 12:32:07
67.234.196.64
| I had a tractor with the same engine that was sitting awhile and when I got it going it started to run away rpms within seconds. Turns out the carb butterfly fell off and went down an intake runner. I picked it out and put it back in the carb and all was well, I guess it spit the screws out the exhaust. Funny because it ran fine when I used it last. |
| mkirsch
10-24-2012 11:17:20
64.80.110.74
| This isn't something you can adjust away. Like old says, they don't go out of adjustment just sitting.
I second trying to move the carburetor linkage as a test. It should move freely when the tractor isn't running. It should move then snap right back when the tractor is running,
As long as the linkages are free, a racing engine means the internal spring inside the governor has broken. It is not a difficult fix, but you do need to remove the governor housing.
There are six bolts holding the governor housing to the engine, one cotter key holding the throttle lever rod, and one more cotter key and pin holding the carburetor linkage.
Support the housing and don't let it fall. The timing gear and governor weights will stay in the engine unless you go totally caveman getting the housing out. Normally there's nothing wrong with the gear or weights.
The housing WILL come out without taking off the radiator. It's a little tight, but if you hold your tongue just right it will come right out. Just keep tipping and turning until you get it.
Once you get the housing off, you'll see a spring broken in two. You will need the OEM part from a CaseIH dealer to get the correct behavior from the governor. |
| 60 Acre Hillsode
10-26-2012 14:44:13
67.142.170.27
Re: Super C engine racing in reply to mkirsch, 10-24-2012 11:17:20
| I doubt it being that spring in the governor. That spring is moved by the throttle lever and if the spring is broken the throttle lever will not move the carburetor from idle. The one who posted to look to see if the shaft from the governor (enclosed in timing cover) is stuck. That is most likely the problem. I had a Cub to that and a lot of moving with a wrench and lots of penetrating oil got it freed up. The original problem was I installed a radiator with the overfloe tube being in the wrong place spewing water on the front timing cover. |
| old
10-24-2012 08:40:10
209.86.226.18
| Do this and it is a simple check. Grab the linkage from the carb to the gov and make sure it moves freely when the throttle is set at the slowest it will go. That linkage should move pretty easy and if pushed all the way open snap back to the idle position fast. If it does not move freely then that is where your problem is and the linkage need to be freed up so it moves easy |
| Russ from MN
10-24-2012 08:19:54
68.235.89.1
| It sounds stuck, that happens from setting. they do not get out adjustment from setting! if you are confident in your ability take the cover off and look for the problem. There are flyweights in there, not magnets. Maybe wait for more knowledgable advice! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
