1966 ford 3000 power steering leak
A previous post suggested I unhook ball joints on
cylinders. I did this and the cylinders stayed
extended.
I saw a post and picture about tubing from
distribution block to cylinders and followed.
Does anyone know the for sure routing, Like top
fitting to inside cylinder??
Also, where is the for sure placement of the
castle plungers and 2 ball bearings as you sit on the tractor??
Also, the ported fitting near the return
on block, is this solid and little ball bearing
captured in it???
Thank you
You would do well to ask Ford questions on the Ford Board.
Click below for an older post from there that explains that steering block.
Rereading it here I see I made a mistake in that old post. Inside the center spool there is a groove on one end. In that old post I said the groove goes up. That is not correct, The groove goes down.
The upper port on the block should connect to the inside port on the cylinder - I think - I have replacement cylinders on mine but assume they are the same as the oem ones.
Untitled URL Link
