Best deal on a 2 stage air compressor
RGMartin
What is the best bang for your buck 2 stage compressor out there?
Any thoughts? The IR that TSC has for a $1100 is leading the pack at the moment.
I researched this rather thoroughly about two years ago before buying an Eaton Air, now DBA Polar Air. They will sell direct. Google for website.
You get what you pay for.
A bargain price is not always a bargain. Check the CFM's. For the average farm shop I wouldn't get anything less than 17-20 CFM's and a true 5HP motor that pulls, I think, 22 amps if you don't do much sandblasting. A good one will set you back about three times that $1000 amount. On the other hand, if you're just filling tires and using a 1/2" air wrench once in awhile, a cheaper compressor will run you awhile. Jim
It all depends.
Curtis
Saylor-Beale
Quincy
Gardner-Denver/Champion
Jenny
SOME IR compressors
are all top tier compressors. Jenny (the steam cleaner people) formerly made the pumps for the large Emglo compressors. After Dewalt destroyed Emglo, Jenny started making whole compressors themselves.
Many of the IR pumps are made in India and are not of the quality you expect from IR. I have read on the net of significant quality problems with some of the small IR two stage units.
If you step down a little, there are several other two stages that will perform well for the money. I have a Home Depot Husky true 7.5 hp 80 gal two stage that is made by Campbell Hausfeld. This is a quality compressor. Mine has a USA pump, the newer ones have the same pump, but made elsewhere (at least they no longer say USA on them)
American IMC/BelAire assembles a compressor in South Carolina using US and foreign components. These units have a pretty good reputation. I seem to recall they use an Italian made pump.
An outfit called LaPlante Compressors is making industrial compressors using the old Kellogg pump design, and while I know nothing about them, if the pumps are well made, the Kellogg design is a excellent pump.
Be sure that whatever you buy has a true horsepower rating. A true 5 hp, which is about the minimum for two stage units will put out about 18 cfm and. A true 7.5 hp will produce about 24-25 cfm.
Charles
I need it for running 3/4" impacts, some spraying, some blasting. I know I need considerably more than I have now.
CP would be nice from a historical standpoint as my grandfather built/rebuilt compressors for them many years ago. Any insight on them currently?
CP as in Chicago Pneumatic? Don't think they ever had their own pump design, maybe before my time. These days they are global all the way, everything is rebadged. So look carefully at what you are getting.
I have a 7.5 hp Porter Cable that will out run my pressure blaster and any other tool I put on it. I don't know if they build it or someone else but it does have an A.O. SMITH motor.
(quoted from post at 09:45:11 10/23/12) CP as in Chicago Pneumatic? Don't think they ever had their own pump design, maybe before my time. These days they are global all the way, everything is rebadged. So look carefully at what you are getting.
Yeah, that CP. Their plant was in Franklin, PA. Just another shell of a brick building now.
Just to keep it tractor related, The last new tractor he bought was a 770 Case which I still use.
Brief history from 1951:
http://www.energymachinery.com/html/cph.html
I have an INDUSTRIAL Quincy, that has an oil pump
and full pressure lubrication, and even an oil
pressure gauge. "Northern", and "TP' (the sand
blaster outfit)sell Quincy, but specs say "Splash
Lubrication". Be aware of what you're getting!
I Owned a tire shop for 22 years, Ingersol Rand type 30 is the only compressor we bought that is still in constant operation today. Health reasons forced me to sell the shop 6 years ago. It is the only brand of compressor I would buy new.
This gets beaten to death daily at http://www.garagejournal.com/forum/ do a search. The best brands are Saylor-Beall, Champion, Quincey they are kind of like autos everyone has an opinion.
Just make shire you get a 5hp oil lubed model, You should be very happy with it. Realize air is very pricy there is no cheep way if you need it.
