Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: aluminum gutters
MarkB_MI
10-21-2012 06:21:48
Stephen, I'm afraid you have it backwards. To prevent ice dams, you need a cold attic. If the roof temperature stays the same temperature from peak to eave, ice dams won't form. Ice dams form when the roof over the attic is above freezing, and the roof over the soffit is below freezing. This usually happens at night.
Adding insulation to the soffit will do nothing to prevent dams, because there's no heat source to warm the roof. But adding insulation and ventilation to the attic will prevent snow from melting when the outside temperature is below freezing.
I never heard of ice dams while living in the Texas panhandle. And down in SE Michigan we have it easy compared to folks in the Upper Peninsula.
Stephen Newell
10-21-2012 18:38:37
 Re: aluminum gutters in reply to MarkB_MI, 10-21-2012 06:21:48
Actually the point I was trying to make is to force the heat all the way out to the soffit area heating the roof there so the water will drain off the roof not making a damn in the first place.
