Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Log splitter engine hard to pull.
GUIDO
10-20-2012 06:29:22
Hello George Marxh,
B$S has had "easy spin" starting for years!
The old system always had the exhaust valve openig even on the compression stroke. Even though it did so, it was a mere 1/200 of a second at 3600 R.P.M.'s. the exhaust valve stayed open 1/100 of a second at start up speed. Force required to start the engine was reduced by 50%, and would be noticed by wimps er people that had trouble starting an ordinary engine.
Now How do you check compression when you know that the engine has a compression release?
Guido.
George Marsh
10-20-2012 16:06:09
 Re: Log splitter engine hard to pull. in reply to GUIDO, 10-20-2012 06:29:22
Hello Guido,
I don't worry about compression on a small engine. If it fires and runs, that good enough for me. Don't know how you would check it with compression release. I buy most of my small engines new, take care of them and don't have too many problems.
When briggs had 3.5 hp flat heads, I would have problems with exhaust and intake valve seat recession. Had to grind a little off the valve stem.
With overhead valves, I've had about 6 that needed the exhaust valve clearence tightened up.
Have a 20 hp kohler command with hyd valves. No problems at 1200 hours.
George
George Marsh
10-20-2012 15:23:53
Hello Guido,
George
GUIDO
10-20-2012 15:40:17
 Re: Log splitter engine hard to pull. in reply to George Marsh, 10-20-2012 15:23:53
Hello George Marsh,
The old flat heads were prone to exhaust valves and seat burning.
To chech for compression on an engine with a compression release, you bump it the opposite direction of rotation.
If it kicks back the compression is good........................Now you know!
Guido.
Copyright © 1997-2015 Yesterday's Tractor Co.
