Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: What size propane line?
propanedude
10-18-2012 06:59:17
yellow plastic gas line for underground is the way to go. half inch cts{copper tube size}is big enough. comes in 500ft rolls. dealer cost is 12cents per foot. you need a tracer wire in the trench so it can be located later. quick connect risers are needed at each end of tube. dealer cost $28 for 84inch,$21 for short one. you need low pressure regulator at the building. dealer cost for a good rego is $35.00. your propane dealer should have everything and prices are usually marked up30 to 60 percent. if you have the trench dug and your dealer only has to lay in the line,make connections, and leak check the service call should be very fair and cheaper than using copper tube. you must use forged fittings wirh copper. regular fittings will crack eventually if exposed to water and freezing temps.
