| Tool Talk Discussion Forum |
Topic: filling bottle jacks
[Return to Forum]
| Author |
[Modern View]
| caterpillar guy
10-17-2012 17:29:42
68.188.235.228
How do you fill a bottle jack so it doesn't. Either not go all the way up, or after you release it it goes back up part way on it's own, from the oil being under pressure from pushing it back down. |
| caterpillar guy
10-18-2012 06:50:56
68.188.235.228
Re: filling bottle jacks in reply to caterpillar guy, 10-17-2012 17:29:42
| I'll try the filling method. Thanks The one I had trouble with if I got enough fluid to run the ram out fully it would then push the ram out when down. If I took the fill plug out it would work fine until the plug was put back in. If I pushed the ram down then put the plug in it would create a vacuum and not let the oil into the plunger to push the ram out. |
| Stephen Newell
10-18-2012 04:50:03
66.53.81.147
| I just had to do that a few days ago for the first time. I took the fill plug off and it would only take a few drops. I figured out that if I lifted the arm as I was filling the fluid would go in. Then with the arm up I put the plug back in and let the arm go down and repeated the process. May not be the correct procedure but it worked. |
| Ted in NE-OH
10-17-2012 18:46:54
173.189.169.175
| Look at a post below for a discussion on Hydraulic Jacks and how to get the air out. |
| H2OK9
10-17-2012 17:44:53
71.50.17.172
| With the jack sitting upright (never fill a bottle jack while laying on its side) on its base and the ram fully retracted, (all the way down) remove the fill plug. fill the jack with hydraulic jack oil. I found the easiest way to do this is fill a squirt oil can full of fluid and use this to fill the jack. after the jack is full to fill hole, open the valve and pump the jack slowly for 10 to 20 strokes on the plunger. (this will help bleed the air if jack was sitting on its side or empty). recheck the oil level, and making sure it isn't overfilled, replace the plug. If the seals and cups are in good shape, the jack should be ready for use. |
| jaden
10-17-2012 17:36:11
98.16.177.127
| Fill to the oil level screw with the jack in it's normal upright position. If the ram springs up, you've got air trapped. Work it up and down a few times with the oil fill screw out. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
