TractorLinks.com
Tool Talk Discussion Forum
Re: GX390?
Billy Shafer
10-16-2012 07:57:34
Almost forgot. Valves
Intake 0.15 MM
Exhaust 0.20 MM
George Marsh
10-16-2012 10:09:46
 Re: GX390? in reply to Billy Shafer, 10-16-2012 07:57:34
Billy, thanks for the info.
Bought pressure washer used. It has no hour meter. As for compression, YES, that's what makes so hard to start. Sometimes it fires too early and pulls the starter out of my hand.
Going to check valve clearance and put a thinner oil in it.
George
Billy Shafer
10-16-2012 15:21:47
 Re: GX390? in reply to George Marsh, 10-16-2012 10:09:46
George. Those are cold settings. The cam lobe controls compression release. No other way that I know of. Briggs has the same system.I should have the 390 manual somewhere around my nice clean office.I will check.
George Marsh
10-16-2012 19:36:47
 Re: GX390? in reply to Billy Shafer, 10-16-2012 15:21:47
Billy,
I adjusted the valves when cold. Exhaust was only about .002 in out. I did notice the exhaust valve opening a little on the compression stroke? Does the cam do that? Are there 2 lobs on the cam?
George
JDseller
10-17-2012 03:33:23
 Re: GX390? in reply to George Marsh, 10-16-2012 19:36:47
The cam has a weight that is on a lever. That lever turns a small shaft that has an eccentric on the end of it. That eccentric sticks out into the exhaust lobe of the crankshaft. The weight it held one way with a spring. So at low speeds the eccentric will open the exhaust valve a little at crank speeds. When the engine hits and comes up to running speed the weight over comes the spring pressure. Then the eccentric is flush with the cam lobe and no longer hits the exhaust valve.
Have you tried a new spark plug. I have a JD pressure washer that has a Honda motor on it. If it starts hard it usually is the spark plug not firing right under compression. Also are you able to crank it good and fast??? As my Dad has gotten older he can't pull the rope fast enought for small engines to start correctly. He complains about this one or that one not starting correctly. Me or my sons can just give it a good yank and the engine starts fine.
I have actually mounted a few snow blower motors on some of the things he uses with a small gas engine on them. The snow blower motors have 110 volt electric start on them. So he can just plug in the cord and hit the button and away he goes.
One of his motors was the same model as one used on snow blowers. I was able to change the flywheel to one that would use the electric starter.
George Marsh
10-17-2012 04:35:03
 Re: GX390? in reply to JDseller, 10-17-2012 03:33:23
JDseller,
I'm looking for a flywheel and starter. I think my problem is I'm getting old. 3 days later my arm and sholder is still hurting from pulling on the starter.
May buy myself a new pressure washer with a starter for Christmas.
My 6.5 briggs on a pressure washer is a dream to start, but the gismo that adds soap and bleach is broken. It's built into the pump. I would have to buy a new pump to fix the problem. I need to do something, still have 3 properties to clean.
George
