TractorLinks.com
Tool Talk Discussion Forum
Re: Ford 532 Baler Disaster
mazemeister
10-15-2012 17:37:57
on why did it break: probably the most important question. i had a knotter cam gear break on my JD 224T. When it went through a tying cycle, the knotter gear and the twine disk pinion would try to force each other apart. after scratching my head a little while, i replaced the twine disk pinion and that solved the problem. the old one showed a little wear, but it didn't look too bad. turns out it was. so if you find a replacement gear, i'd sure look into that pinion also. probably the same thing would happen with the billhook pinion if that wears.
Nathan Skipper
10-15-2012 19:20:49
 Re: Ford 532 Baler Disaster in reply to mazemeister, 10-15-2012 17:37:57
There is some ware in both pinions, but that didn't happen until the disc pinion started skipping, which I think was actually brought on by the failing cam, not the other way around.
My friend (as Providence would have it) had a whole knotter assembly that I just picked up. It's OLD and rusty, but the cam is good on it. I spent the better part of the night trying to get it off the shaft. I'll let the oil sit in and try again when I have some more time. If I can get it off of there, I should be good to go, at least until the next part breaks.
