Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Good Starter Compressor?-What tools will it Run Well??
RodInNS
10-15-2012 12:46:27
If you do much of anything with a compressor you'll want something that makes 12-15 cfm @ 90 psi with a maximum of at least 125 psi... and an oil lubed pump. They generally call those about a 5 hp compressor. Mine is also a portable type rather than a standup. That works OK for me because I hide it under the work bench...
I can also take it if I need it elsewhere.
It'll be a bunch more money but somehting that will outlast you more than likely. One of my neighbours has had probably 5 of those small lube free compressors in the time I've had mine and does less with it.... They're junk as far as I'm concerned.
Rod
