Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Ford 532 Baler Disaster
RodInNS
10-15-2012 09:09:29
Watch the consignment sales...
You might also be able to braze this one or weld it with a Sodel 35 rod if you're into that. Depending on how or where it broke would make up my mind on how I repaired it. If the repair needs to be machined flat I'd probably weld it with the Sodel 35 rod. If there's room to allow a weld bead to pass with a lot of buildup I'd probably braze it...
Rod
Nathan Skipper
10-15-2012 09:36:29
 Re: Ford 532 Baler Disaster in reply to RodInNS, 10-15-2012 09:09:29
Unfortunately, I'm not at all familiar with welding. I wish I was. Also, it broke right at the axle, and it would probably be better to describe it as shattered. I've been hunting down salvage yards and used parts warehouses, but I haven't had much luck yet.
This may be a completely batty idea, but could a cam gear kit from another baler (say a NH baler from the same era) work in its place?
RodInNS
10-15-2012 12:55:29
 Re: Ford 532 Baler Disaster in reply to Nathan Skipper, 10-15-2012 09:36:29
The NH part may fit... but probably not. The critical parts like the bill hooks ARE the same... but once you deviate out further in the larger parts the design is different.
What you can do is go to NH online parts and look up what you need. Then take that number and plug it into Messicks parts online and see if it supercedes to something else. If it does, keep following it and see if it's available or what it fits.
A NH dealer can also plug the part # into PAL and see what else it fits besides that baler.
They may also be able to still do a parts broadcast requesting any other dealers with NOS on the shelf to fill your part order if they wish. They used to have that feature anyhow... unless that's been done away with.
As far as the shattered part... if you can find the crumbs sometimes Humpty can be put back together. You just need the critical stuff to get the angle right. Cast usually breaks pretty clean without distorting so as long as you can jig it the way it needs to be set and hold it... someone with cast experience can probably weld it.
I don't know of any wreckers that would bother keeping a baler like that in the yard. You could try Fawcett tractor. They might also steer you to someone who does wreck that stuff.
I find that every year or so I see a 532 or 542 in the junk sale. I've yet to drag one home... The last one was kinda nice and went for over 650 which I thought was a bit dear for a parts haul... that I'd have had to float home because it had junk tires.
Rod
Nathan Skipper
10-15-2012 19:28:50
 Re: Ford 532 Baler Disaster in reply to RodInNS, 10-15-2012 12:55:29
After working their website to the bone, I finally called the parts hotline for messicks. Very helpful people. They did find a warehouse for obsolete parts that has the entire knotter assembly, but they're wanting $800+, and it weighs 70 lbs, so shipping is going to add a good bit to that.
On a brighter note, my friend had an almost complete knotter assembly off a ford baler, and the cam gear looks good on it. The trick right now is getting the sucker off. The rest of the assembly is rusted into a solid piece, just about, especially around the shaft. I'll peck away at it till I get it off of there, and maybe that will have me back in business for spring. Thanks for the help.
cd1
10-16-2012 08:45:45
 Re: Ford 532 Baler Disaster in reply to Nathan Skipper, 10-15-2012 19:28:50
That might be cheap but before I spent 800 I would cut my losses and go buy a new holland that I know I can buy parts for. Who knows what might crap out next on the ford, then the 800 was all for nothing.
RodInNS
10-15-2012 19:40:47
If you can get a complete NOS knotter for 800 bucks and intend to keep the baler... I think I'd be all over that. That is so cheap you don't know how cheap yet. Each bill hook is 100 on the nose...
The main things you should be asking yourself is ... how good are the plunger guides and the baler frame generally... along with the hard parts of the pickup. If that's all in good shape most of the rest can be repaired with a bit of ingenuity.
I'm tempted to go after that knotter myself if you don't...
Rod
Nathan Skipper
10-16-2012 10:30:46
 Re: Ford 532 Baler Disaster in reply to RodInNS, 10-15-2012 19:40:47
Actually, I think Messicks said they had two in stock. Either way, go right ahead. I'm going to see how this spare cam gear plays out. I can't bring myself to sink that much more money into it. As has been advised, I'd rather cut my losses and get a baler that's not obsolete.
RodInNS
10-16-2012 13:12:41
 Re: Ford 532 Baler Disaster in reply to Nathan Skipper, 10-16-2012 10:30:46
I can't argue with getting something that's not obsolete... I've said that to many on here, many times... mabey including you.
That said... there's a fair bit of NH stuff that's gotten very obsolete as well. If you're running from that boogeyman... you better jump ahead to something like a 565 or that generation. That will cost a lot more money that a knotter stack...
I don't mind spending a bit of money on something like that IF the rest of the machine is still usable.
Rod
Nathan Skipper
10-18-2012 09:13:42
 Re: Ford 532 Baler Disaster in reply to RodInNS, 10-16-2012 13:12:41
Rod,
New development. I told messicks I didn't want it, and they came back and said the obsolete supplier is looking to clear that inventory. They dropped the price to $495. I've both one of them, but they have another one left. You may want to call and see if they will do the same for you. A brand new cam gear with pinions is $375. $495 for the whole knotter assembly... how bout that?!
RodInNS
10-19-2012 07:59:25
 Re: Ford 532 Baler Disaster in reply to Nathan Skipper, 10-18-2012 09:13:42
Is this stuff on Messick's shelf or the aftermarket supplier? If it's on the aftermarket supplier's shelf it might be more to my advantage to go through my own dealer...
Rod
Nathan Skipper
10-19-2012 10:34:03
 Re: Ford 532 Baler Disaster in reply to RodInNS, 10-19-2012 07:59:25
It"s on the supplier"s shelf.
cd1
10-16-2012 18:43:12
Atleast in my area you will find about 100 new hollands to 1 ford so even if the part is NLA you have a chance of finding it. I run a 326 myself.
Nathan Skipper
10-15-2012 13:14:16
Thanks for the response... very helpful. I think I might have lucked up... but I will know for certain after work. I just found out that a friend of a friend has some old ford baler parts, and he actually has a whole knotter assembly. I sure hope it works out.
If it doesn't, I will definitely try your idea of tracing down the part number on messicks and contacting Fawcetts. I tried ordering the part from Messicks, which is how I came to know that it is discontinued. But, they haven't responded to my question about cross-matching parts. Maybe they will, though.
It is strange how this stuff is both irritating but fun at the same time. Irritating, that I bought equipment that broke and have crop wasting on the ground, yet fun in the inventive and investigative sense. Or maybe I'm just masochistic.
Dusty MI
10-15-2012 09:43:42
Why did it break ?
Nathan Skipper
10-15-2012 11:50:48
 Re: Ford 532 Baler Disaster in reply to Dusty MI, 10-15-2012 09:43:42
I really don't know why it broke, other than it was worn out. Maybe it was something I did. There was a lot of distance between the pinion and the cam gear and it was causing the pinion to miss and get stuck on the return so that it would no longer turn. So, I tightened the stack using the adjusting nut. There was still some play in the pinion, so I don't know if the cam was already weak or what. The LH cam seems solid as a rock.
mazemeister
10-15-2012 17:37:57
 Re: Ford 532 Baler Disaster in reply to Nathan Skipper, 10-15-2012 11:50:48
on why did it break: probably the most important question. i had a knotter cam gear break on my JD 224T. When it went through a tying cycle, the knotter gear and the twine disk pinion would try to force each other apart. after scratching my head a little while, i replaced the twine disk pinion and that solved the problem. the old one showed a little wear, but it didn't look too bad. turns out it was. so if you find a replacement gear, i'd sure look into that pinion also. probably the same thing would happen with the billhook pinion if that wears.
Nathan Skipper
10-15-2012 19:20:49
 Re: Ford 532 Baler Disaster in reply to mazemeister, 10-15-2012 17:37:57
There is some ware in both pinions, but that didn't happen until the disc pinion started skipping, which I think was actually brought on by the failing cam, not the other way around.
My friend (as Providence would have it) had a whole knotter assembly that I just picked up. It's OLD and rusty, but the cam is good on it. I spent the better part of the night trying to get it off the shaft. I'll let the oil sit in and try again when I have some more time. If I can get it off of there, I should be good to go, at least until the next part breaks.
