| Author |
[Modern View]
| tomNE
10-12-2012 21:25:32
75.221.119.65
need idea's on a mechanical way to remove them. right now i clip and spray them. it's back breaking work. wondered about a 3point peice of equipment that would do it without digging a big hole. the cedars won't regrow if cut off at ground level or below. i understand i'll need to spray the locusts. any ideas are welcome.....i've even thought of something that would mount on the front of a 4 wheeler. the 3point piece would be nice if it faced forward so u could just straddle the tree and lower the implement! |
[Reply] [No Email] | |
| jackinok
10-16-2012 08:15:22
162.58.82.136
Re: cedar trees and small locusts in crop ground in reply to tomNE, 10-12-2012 21:25:32
| can you pull them with a chain? i think northern tool sells grubbing chains that basicly clamp on small trees so you can pull them.like you say ,cedars wont come back if you cut them below lowest limb, but those locusts just seem to spread from roots if you disturb them.might have to take something like a subsoiler to cut those roots and some brush spray to really get a handle on them. |
| Chip812
10-14-2012 15:12:18
98.89.119.18
| Kirk Affeldt
10-14-2012 11:14:33
74.47.9.33
| I was watching Succesful Farming TV show and on their All Around the Farm episode, a guy in Minnesota made a hydraulic tree remover for his tractor. It seemed very simple to make and he didn't use much money to make it. He used it to pull cedar trees on his property. He didn't want to leave a big hole and his remover didn't. It just pulled them right out of the ground. You may want to check it out on their website. |
| Dean
10-14-2012 05:54:28
67.172.15.77
| | Yesterday I removed 5 or 6 locust stumps from a plot that I intend to plow for the first time in nearly 100 years. (The plot has been farmed in the past.) The trees were cut nearly 40 years ago and I cut the stumps flush with the ground about 25 years ago so that I could mover over them with a rotary cutter withoug hitting anything. After 40 years I had hoped that the stump remnants would plow out but since the neighbor was here with his new CAT skid steer for another job I asked him to pop them out. The wood below ground level was in surprisingly good condition and hard as a rock. There is no way that they would have plowed out. All of the other stumps, e.g., elm, maple, box elder, etc., had long since vanished. Dean |
| Dusty MI
10-14-2012 09:42:53
76.247.154.39
Re: cedar trees and small locusts in crop ground in reply to Dean, 10-14-2012 05:54:28
| There was an old story, locust make good fence post, they will last 100 years, I know I once built a fence using them.
Dusty |
| Bradracer18
10-13-2012 19:43:51
173.215.8.237
| We have a tree shear that mounts to our skid loader. It just pinches off the tree, but was also can replace the shear blades with little grabber spikes which we use for pulling fence posts. Anyways, once you shear the tree, we have a automotive windshield washer pump system that sprays tordon onto the stump, and it shouldn't be a problem after that. |
| bookemdano21
10-14-2012 08:45:10
208.126.99.22
Re: cedar trees and small locusts in crop ground in reply to Bradracer18, 10-13-2012 19:43:51
| how did you mount your windshield washer sprayer? |
| JerryD
10-13-2012 18:58:55
68.92.139.222
| If the cedars aren't too big you can use a weedeater with a small circular saw blade attached. Just make sure you know where that blade is at all times. |
| charlie n
10-13-2012 14:25:51
96.35.24.196
| I saw this advertised in Progressive Farmer.
http://www.drpower.com/prdsell.aspx?Name=treechopper |
| tomNE
10-13-2012 06:06:21
75.235.24.118
| keep the ideas coming.....so far nothing that strikes my fancy!!! |
| old
10-14-2012 10:12:25
209.86.226.27
Re: cedar trees and small locusts in crop ground in reply to tomNE, 10-13-2012 06:06:21
| I was always told cedar tress and locust tress are a sign of poor soil conditions. If small brush hog or sickle bar mower. Of course a lot depends on what crops your putting in and what you do as for soil preparations. |
| tomNE
10-14-2012 10:49:01
75.221.177.225
Re: cedar trees and small locusts in crop ground in reply to old, 10-14-2012 10:12:25
| there is no soil prep. it's been no till for 20+ yrs. this ground surrounds the timber/waste ground on my farm. maybe i need to spend my time potty training the birds, not to leave the timber without doing there duty first! |
| old
10-14-2012 12:17:27
209.86.226.19
Re: cedar trees and small locusts in crop ground in reply to tomNE, 10-14-2012 10:49:01
| A no till type of thing makes it a good bit harder to do much. What type of crop do you do?? |
| 2x4
10-13-2012 00:57:09
75.106.104.202
| box blade with ripper teeth |
| da.bees
10-12-2012 23:12:15
72.181.183.240
| You are correct that cedar will not regrow enough to be a problem. The locust will resprout from roots with a vengance. 2-4-D does a good job on the resprout locust. Both stumps will cure and be in place years later equvilent to rebar if run over by tires. Only good news is the locust has fixed nitrogen in the soil that will remain a long while. |
| JDseller
10-12-2012 21:55:05
208.126.196.144
|   There are commercial tree shears/knifes that would do what you want to do. Some of them shear the trees off. Then others are just like a flat serrated knife that you push beside the tree and it cut them off at or below ground level. I attached a picture of them both. The flat knife type I could not find a picture of the one I have seen. This one gives you an idea of how they work. |
| 504
10-12-2012 21:43:07
64.111.61.44
| Bush Hog, if I can drive over it, I will mow it. |
