Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Topic: cutting aluminum
[Return to Forum]
Chris Jones
10-09-2012 21:14:26
98.26.240.6
I was given the pole from a broken pole pruner and the saw blade that bolted on the side of that pruner. The pruning head on the end of the pole that held the blade broke and was discarded. I have decided to insert a wooden dowel (broom handle fits perfect) into the end of the aluminum pole then slit the pole and wooden center lengthwise about 4 inches to sandwich the saw blade inside. I'll drill two holes through the pole, wooden center and blade and bolt it on giving me a sturdy pole saw.
I'd like to cut them at the same time so the slit lines up but I could do it separately and hope I hit center on both. I have a wood band saw but the only blade I have is pretty course and it cuts crooked. I have a metal band saw too but it's made for cutting steel. I have a table saw with a variety of wood blades and abrasive blades for steel. Other options are hand sawing with a coping saw or hack saw or I have a 3 inch air cut off tool with abrasive blades. What's the best way to split the pole and wood dowel.
[Reply]   [No Email]
Pops1532
10-11-2012 05:22:40
98.227.131.18
Re: cutting aluminum in reply to old, 10-09-2012 21:14:26
It doesn't need to be carbide.
I've cut over a thousand of squares of aluminum siding (cutting through 5 or 6 pieces at a time) using non carbide blades.
  [Reply]  [No Email]
Pops1532
10-11-2012 04:52:35
98.227.131.18
Re: cutting aluminum in reply to Chris Jones, 10-09-2012 21:14:26
I guess I'm late to this thread.....a plywood cutting blade installed backwards on a table saw would have been the best.
  [Reply]  [No Email]
Chris Jones
10-11-2012 05:06:01
98.26.240.6
Re: cutting aluminum in reply to Pops1532, 10-11-2012 04:52:35
Your probably right. I'll try to keep that in mind for next time. Of course my plywood blade isn't carbide toothed but given how easily it cut I think it would work fine.
  [Reply]  [No Email]
evilboweviel
10-11-2012 07:38:36
75.185.55.222
Re: cutting aluminum in reply to Chris Jones, 10-11-2012 05:06:01
never run a carbide blade backwards
only use a steel blade backwards
  [Reply]  [No Email]
Chris Jones
10-10-2012 20:35:28
98.26.240.6
I decided to cut it with a 7.25 inch blade on my 10 inch table saw using a carbide ripping blade. It's done. The project could have gone smoother but it wasn't bad.
  [Reply]  [No Email]
PJH
10-10-2012 06:31:37
50.40.250.173
Chris - if it is a Fiskars brand pole trimmer, they have a very good warrantee. I got one for Father's day a couple of years ago. Broke something on the head - called the company and they sent a whole new head out to me. No charge.
Otherwise - as Dusty said - the blade slot needs to be the thickness of the blade that goes in the slot. . .
Paul
  [Reply]  [No Email]
Dusty MI
10-10-2012 04:32:27
76.247.153.8
I would pick the saw that left a kerf the same width as the saw you are going to install in it.
Dusty
  [Reply]  [No Email]
jon f mn
10-10-2012 04:24:07
70.196.3.121
A regular carbide wood cutting blade works perfect for cutting aluminum. You can use anything that would use that blade, hand saw, table saw, mitre saw. Most places that sell aluminum by the piece use a wood mitre saw to cut aluminum pieces now. Any metal saw will work also, but they will kind of gum up with aluminum. You can prevent that by spraying them with lube like wd40 or nozle dip or spray for welding works even better. Candle wax also works. Grinder blades will also work, but again will get gummed up. Just run them against a candle or smear some nozle dip on them first to prevent that.
  [Reply]  [No Email]
Dauber
10-10-2012 13:10:31
205.213.202.4
Re: cutting aluminum in reply to jon f mn, 10-10-2012 04:24:07
Rubbibg the cut off blade with a bar of soap works great too. I use Dial.
  [Reply]  [No Email]
jon f mn
10-10-2012 20:29:34
70.195.6.63
Re: cutting aluminum in reply to Dauber, 10-10-2012 13:10:31
I bet bar soap would work good. Never thought of that.
  [Reply]  [No Email]
MarkB_MI
10-10-2012 02:38:45
75.219.98.130
Your best bet is to put a metal-cutting blade in your woodcutting bandsaw.
You should be able to do the cut freehand. But if you want make sure the cut is perfectly straight, do this: Take a piece of scrap wood and mark a line parallel to one edge. This should be on the edge where you would want a rip fence to go if you hand one, probably on your left-hand side as you face the saw. The rip line should be offset from the edge the same distance as the radius of your pole. (half the pole's diameter). Rip this line for a few inches, keeping the blade right down the center of your line, then stop without moving your scrap from the saw. The scrap will be at an angle to compensate for the drift of the saw blade. Now clamp another scrap of wood to the the saw table to form a fence for the first piece. You can then continue to saw the scrap and adjust your fence until the blade tracks your mark perfectly. You now have a fence set at the right position to split your pole.
  [Reply]  [No Email]
Stick welding
10-09-2012 21:55:37
96.53.210.246
A metal cutting blade would cut both. A zip disc in an angle grinder would work too.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
