Name this tool.
Stephen Newell
I know what the thing is. We had a wrecker company haul our car home the other day and left this hook attached to the car. I would like to know what it is called so I can locate and buy one for myself.
Thanks, It always helps to know what your shopping for. Nearly every vehicle I own has really no place to hook a tow chain. The cluster hook looks like what I've needed all along. I had just never seen one before.
there are hook points in the frames / uni-body rails on all vehicles. some round holes, some slots, for either the tee cluster, or hook type cluster. there are books that list vehicle type and hook points along with what type cluster hook you use. we have them in all our tow trucks. you can also get a bridle that has clusters on each end, then the winch line hook in the center, or, a bridle with j hooks.
here is a cluster/bridle and a j hook bridle set up
<a href="http://s121.photobucket.com/albums/o234/glennster_01/?action=view&amp;current=DSCF2970.jpg" target="_blank">
DSCF2970.jpg" border="0" alt="Photobucket
</a>
Untitled URL Link
My Dad hauled cars out of Lansing, Michigan for 27 years, they are "T" or "R" hooks or sometimes called frame hooks. They used to use "J" hooks but at some point GM told them they couldn't use the "J" s any more only T's and R's. This time of year was always interesting if there was a significant change in the cars as the trucking company figured out what/how many they could haul on the various types of trucks and what/where they couldn't tie down without damaging the cars. With The car carriers it was hard to slip by with being overweight, after about 2-3 weeks commercial carrier enforcement had a pretty good idea of what to count on the truck to know if they were overweight. Example one year if you had any combination of more than 5 88's or 98's they knew you were at least 500#s over on the drive axle. Another year if they didn't see at least 3 Cutlasses they knew you were over gross weight.
I have 3 or 4 of the T type hooks. I bought them, used them once and decided to do something different. I'll part with them for 1/2 price.
Dusty
