TractorLinks.com
Tool Talk Discussion Forum
Re: Power Washer
George Marsh
10-03-2012 10:00:48
Bill,
I would think that if you are starving a pressure washer, it would make air bubbles.
If I don't purge the water hose before starting the washer, it stops until the air is worked out of the pump.
Every 28 inches of water column will make 1 psi. You may need to raise your tank. Can you add air pressure to your storage tank?
I like using rotary nozzles. Have you tried them?
I never have less than 20 psi going to my pressure washer, so I can't say what happens with low pressure going to the pump.
Does your 1/2 inch pipe deliver 3 gallons per minute? Most pressure washers use less than that, 2 + gallons/min. Try increasing the pipe size.
Take a pump and boost the water pressure before goes to the pressure washer and see what happens.
LOL
George
bill from scotland
10-03-2012 14:34:34
 Re: Power Washer in reply to George Marsh, 10-03-2012 10:00:48
Thanks all for the advice. I am kinda tied with my water supply as its all plumbed into the house system unless I can get some sort of large storage tank and an auxilary pump. I will have a look on Ebay regarding booster pumps, I may be able to get a 1000 litre tank that I could use as a reseviour.
Bill
dave2
10-03-2012 23:32:25
 Re: Power Washer in reply to bill from scotland, 10-03-2012 14:34:34
Have you got a way to try it closer to the house (normal water pressure) first? Was using mine just with a 1000 liter tank about a meter off the ground (only gravity)... Is there a screen or some type of filter at the input connector that may be restricted?
