Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Compressed air supply line
Ken Macfarlane
10-03-2012 06:14:38
Don't listen to this poster, PVC at cold temps is very brittle, the pieces are very hard to extract if they blow up because x-ray translucent. Its only rated fro 289 psi on water not compressed gases!
Yes a break across the threads isn't too exciting, but a longitudinal rupture is bad.
Also, PVC can break down over time when exposed to some other plastics, I can't recall if it gets brittle or goes soft but it will fail at lower pressures.
No reason to use it for air service.
Stephen Newell
10-03-2012 20:44:31
 Re: Compressed air supply line in reply to Ken Macfarlane, 10-03-2012 06:14:38
I guess you believe in man made global warming too.
Ken Macfarlane
10-05-2012 06:46:56
 Re: Compressed air supply line in reply to Stephen Newell, 10-03-2012 20:44:31
Global warming ain't got nothing to do with it. I'm guessing just because you've never had one blow you don't believe it will happen.
Ever left a rope out in the sun and had it get brittle? Or even just had some plastic container sitting on the shelf inside in the shade a few years that you go to pick up and it falls apart? Happens to PVC too.
