TractorLinks.com
Tool Talk Discussion Forum
Re: Any quick and dirty methods to build up a shaft?
RodInNS
10-01-2012 18:45:46
Shim stock... pull the bearing up the shaft where it's good. Cut the appropriate size piece of shim stock and wrap the shaft, get the bearing fitted. Pull the bearing off again, apply a liberal coat of green Loctite (bearing retainer) and slap it all back together. Run it up so it centers and runs in, then let it set overnight. Should work fine.
Otherwise you can build it up with 7018 and freehand grind it with a flap disc on a grinder. That's rather imprecise...
Rod
